Model railroad crossing
Could someone please help. I would like to be able to change the angle of each servo independently but cant do it.
Thanks, Wally.
#include<Servo.h>;
int pos = 45;
Servo servo1;
Servo servo2;
  pinMode(2, INPUT);
  pinMode(3, OUTPUT);
  servo1.attach(10);
  servo2.attach(9);
  while (digitalRead(2) == LOW && pos < 45) {
    pos++;
    servo1.write(pos);
    delay(40);
    servo2.write(pos);
    delay(40);
  while (digitalRead(2) == HIGH && pos > 15) {
    pos--;
    servo1.write(pos);
    delay(40);
    servo2.write(pos);
    delay(40);
If you want the servo positions to be independently controlled then you will need separate loops for each servo.
Steve
You probably just need two separate pos variables - something like
int maxPos1 = 45;
int maxPos2 = 60;
int pos1 = 0;
int pos2 = 0;
byte upPin = 2;
and code like this
while digitalRead(upPin) == LOW) {
 pos1++
 if (pos1 >= maxPos1) {
 pos1 = maxPos1
 pos2++
 if (pos2 >= maxPos2) {
 pos2 = maxPos2
 servo1.write(pos1);
    servo2.write(pos2);
    delay(40);
...R
Thanks for the help, I modified the program using your code example and I can now adjust the servo angles independently.
