MODEM Power circuit control suggestion and improvment
Hi Team,
I'm using the circuit below to control the power of MODEM
In this circuit, whenever the pin M_PWR_CNTRL is high, the PNP transistor is turned off and there is no output.
Whenever the pin M_PWR_CNTRL is low, the PNP transistor is turned ON, then getting output.
so please let know if there is any improvement in this circuit
May I know how you selected the values of R60, R50 and R82?
This is the right way:
For SMD use MMBT3904
Need to find a different MOSFET, the PMV35EPE will not work for 3.8V
How much current does the MODEM need?
@jim-p thanks again; I will try it
