modif code compte a rebours
bonjour je cherche a modifier ce bout de code récupéré par la
pour qu'il fonctionne avec un keypad 16 touche et je bloque voici le code de base
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4); // set the LCD address to 0x27 for a 16 chars and 2 line display
//Definition des broches:
int bouton1 = 0;int etat1;
int bouton2 = 1;int etat2;
//variable de controle
int test1 = 0;
int test2 = 0;
int arret = 0;
//variable de minutage
int H = 0;
int M = 0;
int min_tmp = 0;
int S = 0;
//initialisation
void setup(){
  //definition des entrees
  pinMode(bouton1, INPUT);
  pinMode(bouton2, INPUT);
  lcd.print("hello, world!");
lcd.init();lcd.backlight();
//programme
void loop(){
arret = 0;
H = 0;
M = 0;
S = 0;
  // definition du Timer
  do  {
    if (digitalRead(bouton1) == LOW)
      test1 = 1;
    delay (500);
    lcd.clear();
    //definition de la valeur des heures
    do
      //incrementation heure
      lcd.setCursor(0, 0);
      lcd.print("HEURES");
      lcd.setCursor(0, 1);
      lcd.print(H);
      lcd.setCursor(1, 1);
      lcd.print(":");
      lcd.setCursor(2, 1);
      lcd.print(M);
      lcd.setCursor(4, 1);
      lcd.print(":");
      lcd.setCursor(5, 1);
      lcd.print(S);
      etat2 = digitalRead(bouton2);
      if (etat2 == LOW)
        if (test2 == 0)
          H = H + 1;
          if ( H % 10 == 0)
            H = 0;
            lcd.clear();
          test2 = 1;
        test2 = 0;
      etat1 = digitalRead(bouton1);
      if (etat1 == LOW)
        test1 = 2;
    while (test1 != 2);
    delay (500);
    lcd.clear();
    //definition de la valeur des minutes
    do
      //incrementation minutes
      lcd.print("MINUTES");
      lcd.print(H);
      lcd.print(":");
      lcd.print(M);
      lcd.print(":");
      lcd.print(S);
      if (etat2 == LOW)
        if (test2 == 0)
          M = M + 1;
          if ( M % 60 == 0)
            M = 00;
            lcd.clear();
          test2 = 1;
      else     {
        test2 = 0;
      if (etat1 == LOW)
        test1 = 3;
    while (test1 != 3);
    delay (500);
    lcd.clear();
    //definition de la valeur des secondes
    do
      lcd.print("SECONDES");
      lcd.print(H);
      lcd.print(":");
      lcd.print(M);
      lcd.print(":");
      lcd.print(S);
      if (etat2 == LOW)
        if (test2 == 0)
          S = S + 1;
          if ( S % 60 == 0)
            S = 0;
            lcd.clear();
          test2 = 1;
        test2 = 0;
      if (etat1 == LOW)     {
        test1 = 4;
    while (test1 != 4);
    delay (500);
    lcd.clear();
    //choix de la validation ou de la correction. Bouton1 pour recommencer, Bouton2 pour valider
    do //incrementation minutes
      lcd.print("VALIDER ?");
      lcd.print(H);
      lcd.print(":");
      lcd.print(M);
      lcd.print(":");
      lcd.print(S);
      if (etat2 == LOW)
        if (test2 == 0)
          test1 = 5;
          test2 = 1;
      else     {
        test2 = 0;
      if (etat1 == LOW)     {
        test1 = 1;
    while (test1 == 4);
  while (test1 < 5);
  digitalWrite(13, HIGH);
  digitalWrite(13,LOW);
  //Compte à rebour
  do  {
    lcd.clear();
    lcd.print("fin dans :");
    lcd.print(H);
    lcd.print(":");
    lcd.print(M);
    lcd.print(":");
    lcd.print(S);
    if ( S <= 1)
      if ( M > 0 )
        M = M - 1;
        S = 60;
        if (H > 0)
          H = H - 1;
          M = 59;
          S = 60;
          //instructions à effectuer lors de l'arrivée à 0. Ici, on passe la broche 3 à l'état haut pour le test
          digitalWrite(13,HIGH);
          test1 = 6;
          H = 0;
          M = 0;
          S = 0;
          lcd.clear();
          lcd.print("fini");
          lcd.print(H);
          lcd.print(":");
          lcd.print(M);
          lcd.print(":");
          lcd.print(S);
    S = S - 1;
    delay (1000);
  while (test1 != 6);
et voila le code que j'ai commencer a modifier mais je seiche jarrive a rien j'ai besoin d'aide merci par avance
#include <Key.h>
#include <Keypad.h> /*#define LIST_MAX 10   // Max number of keys on the active list.#define MAPSIZE 10   // MAPSIZE is the number of rows (times 16 columns)
const byte ROWS = 4; const byte COLS = 4;
char keys[ROWS][COLS] = {{'1', '2', '3', 'A'},{'4', '5', '6', 'B'},{'7', '8', '9', 'C'},{'*', '0', '#', 'D'}};
byte rowPins[ROWS] = {A0, A1, A2, A3};byte colPins[COLS] = {5, 4, 3, 2};
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int H = 0;int M = 0;int S = 0;
void setup() {lcd.init();lcd.init();lcd.backlight();}
void loop() { char key = keypad.getKey();
/*if (key != NO_KEY){lcd.print(key);count++;
 if (count==3){lcd.clear();count=0;}}
 do  {if (digitalRead(bouton1) == LOW)
     {test1 = 1;}delay (500);lcd.clear();
      if ( H % 9 == 0){H = 0;} */
      lcd.setCursor(0, 0);lcd.print("HEURES");
      lcd.setCursor(0, 1);lcd.print(H);
      lcd.setCursor(1, 1);lcd.print(":");
      lcd.setCursor(2, 1);lcd.print(M);
      lcd.setCursor(4, 1);lcd.print(":");
      lcd.setCursor(5, 1);lcd.print(S);
if (key){H = key ; lcd.print(key); }
if (H % 25 == 0){H = 0;}}
/*char keypressed = myKeypad.getKey();
 if (keypressed != NO_KEY)
 Serial.print(keypressed);
bonjour,
avant de vouloir modifier un code piqué sur le net, teste déjà ton keypad et comprends comment cela fonctionne.
regarde le github de keypad ICI
jai lu sa déja j'ai tester plusieur possibilité je les est mis en commentaire mais jarrive a rien j'ai besoin d'aide
je comprend pas pourquoi je narrive pas a récupéré l'infos de la touche presser comme dans lexemple hello keypad
pourtant j'ai remis comme dans l'exemple mais sa marche pas
de plus quand je veut incrementer 12 par exemple pour les Heure (H) sa écrit pas aux bonne endroit
pour tant j'ai tester H = key et H == key ,keys,event keypad getkey etc plein de truc mais je bloque si une ame charitable peut m'aider sa serait cool
t'arrive a rien, ok.
mais a rien de quoi?
qu'est ce qui fonctionne et ne fonctionne pas?
as tu essayé le code de github?
si oui, est ce que ca fonctionne?
ou est le
#include <Wire.h>
dans ton code?
j'ai repris a zero j'ai toujour le meme probleme je suis sur que c'est une connerie de rien du tout en + xd
j'ai tester le code de github sa marche pas
aprés c'est peut etre moi qui c'est pas comment me servir du document c'est fort possible aussi j'ai pas compris comment exploiter le document .CPP
j'ai commenter mon code pour essayer d'etre clair
#include <Wire.h>
#include <Keypad.h>
int H = 0 ;
int M = 0 ;
int S = 0 ;
void setup() {lcd.init();lcd.backlight();}
  lcd.setCursor(0, 0);lcd.print("HEURES");lcd.setCursor(0, 1);lcd.print(H);
      lcd.setCursor(1, 1);lcd.print(":");lcd.setCursor(2, 1);lcd.print(M);
      lcd.setCursor(4, 1);lcd.print(":");lcd.setCursor(5, 1);lcd.print(S);
if (key){  /* H est égale a 00 par défault je cherche via le keypad a entré la valeur des heure en format 24 h (ex 17 h 52 m 23s)
  donc la taper le chiffre 1 puis le 7 pour obtenir 17 H puis que sa passe aux minutes  puis aux secondes
  ici je n'est fait que les heure pour le moment vu que je bloque la dessus */
   H =  key ;
  lcd.print(key);
     if ( H % 99 == 0) { H = 0;lcd.clear();}}}
/* mon probleme et que si je tape 1 sur le keypad déja sa affiche 1 a la place des seconde o lieu des heure et
 *  que a la place des heure sa affiche 4 pourquoi je ne sait pas
 *  voir exemple ci dessous le keypad fonctionne et est correctement brancher j'ai tester
touche keypad         affichage         affichage que je veut premier apui       2 e appui
1                      4:0:01               10:00:00                              17:00:00
2                      0:0:0                20:00:00                              24:00:00
3                      5:0:03               30:00:00                              32:00:00
4                      5:0:04               40:00:00                              45:00:00
5                      5:0:05               50:00:00                              55:00:00
6                      5:0:06               60:00:00                              67:00:00
c'est a dire?
j'ai repris mon code a zero mais toujour le meme problme mais je pensse l'avoir cerné
je pensse que c'est lier a l'incrementation d'une valeur
ici par ex
int H = 0 quand je tape lcd.print (H) sa print 0 normale
mais quand je veut donner a H une valeur par ex 10 sa naffiche pas 10 sa affiche une autre valeur et pas a lendroit définit ici lemplacement des heure mais a la place des secondes pareil pour les minute
esque sa seré pas un probleme de converssion ? sa afficherer pas les chiffre en language asc2 ou autre ?
#include <Wire.h>
#include <Keypad.h> //http://www.arduino.cc/playground/uploads/Code/Keypad.zip
int count = 0 ;
int H = 0; // compteur secondes
int M = 0; // compteur minutes
int S = 0; // compteur heures
char key;
//initialisation
void setup(){lcd.init();lcd.backlight();lcd.print("hello, world!");}
void loop(){key = keypad.getKey(); if (key != NO_KEY) {if (key = 'A' ){lcd.clear (); selecttemp(); }}}
void selecttemp (){
count = 0 ;
 do {
lcd.setCursor(2, 1);lcd.print(":");
lcd.setCursor(4, 1);lcd.print(M);
lcd.setCursor(5, 1);lcd.print(":");
lcd.setCursor(7, 1);lcd.print(S);
lcd.print (H);lcd.cursor();
if (key != '*' && key != '#' && key != 'A' && key != 'B' && key != 'C' && key != 'D') {
    lcd.print(key);
       H = key;
         H++;
           count++;
             if(H % 25 == 00){
                H = 00;
                  lcd.clear(); } } } }
while (count < 2) ;
 do {
lcd.setCursor(0, 0);lcd.print ("minutes");
lcd.print (M); lcd.cursor();
    lcd.print(key);
       M = key;
         M++;
           count++;
             if ( M % 60 == 00){
                M = 00;lcd.clear();} } } }
 while (count < 4) ;
do {
lcd.setCursor(0, 0);lcd.print ("secondes");
lcd.print (S); lcd.cursor();
    lcd.print(key);
       S = key;
         S++;
           count++;
             if ( S % 60 == 00){
                S =00;lcd.clear();} } } }
  while (count < 6) ;
do{
lcd.clear();
lcd.setCursor(0, 0);lcd.print("temp");
lcd.setCursor(0,2);lcd.print("press * pour recommencer");
lcd.setCursor(0, 3);lcd.print("press # pour valider");
      if(key == '*') {lcd.clear (); selecttemp();}
      if(key == '#') {lcd.clear (); lcd.print("ok"); } }
   while (count < 7) ;  */
déjà sans regarder plus loin, tes commentaires sont faux :slight_smile:
cherches l'erreur :wink:
lcd.setCursor(colonne, ligne) tes infos se cheveauchent
hello
voici un bout de ton code modifié, il devrait t'aider à te débloquer
#include <Wire.h>
int count = 0 ;
char key;
//initialisation
void selecttemp ()
count = 0 ;
while (count < 2)
 if (key != NO_KEY)
    lcd.print(key);
       H = key;
         H++;
lcd.setCursor(count, 1);lcd.print(H);
count++;
count=3;
while (count < 5)
    lcd.print(key);
       M = key;
lcd.setCursor(count, 1);lcd.print(M);
count++;
 while (count < 4) ;
do {
    lcd.print(key);
       S = key;
         S++;
           count++;
             if ( S % 60 == 00){
  while (count < 6) ;
do{
lcd.clear();
   while (count < 7) ;
merci pour ton aide mais c'est pareil
je tape 1 j'obtien sa : heures
50: 0: 01
je comprend pas j'ai tester avec un ecran non I2c c'est pareil
j'ai l'impression que c'est avec le lcd.print (H) que sa merde y a une autre fasson de faire ?
lcd.setCursor(count, 1); c'est quoi cette commande je connait pas ?
#include <Wire.h>
int count = 0 ;
int H = 0; // compteur heures
int S = 0; // compteur secondes
char key;
//initialisation
void loop(){key = keypad.getKey(); if (key != NO_KEY) {if (key = 'A' ){lcd.clear (); selecttemp () ; }}}
void selecttemp ()
count = 0 ;
while (count < 2)
 if (key != NO_KEY)
    lcd.print(key);
       H = key;
         H++;
lcd.setCursor(6, 1);lcd.print(M);
lcd.setCursor(7, 1);lcd.print(":");
lcd.setCursor(10, 1);lcd.print(S);/*
count++;
count=3;
while (count < 5)
    lcd.print(key);
       M = key;
count++;
 while (count < 4) ;
do {
    lcd.print(key);
       S = key;
         S++;
           count++;
             if ( S % 60 == 00){
  while (count < 6) ;
do{
lcd.clear();
   while (count < 7) ;
merci de votre en tout cas faut que je trouve !!!! et je trouverer
je n'avais pas vu
dans ton code d'origine, tu saisi des "chars" qui sont les codes ascii de ce que tu tapes
tu tapes "1", puis dans ton prg tu l'incréméntes et il vaut "2". le code ascii de "2" est "50"
je ne peux tester le code
le voici en partie modifié.
testes le tel quel, il devrait fonctionner pour les heures et les minutes
#include <Wire.h>
int count = 0 ;
char key;
//initialisation
void selecttemp ()
count = 0 ;
while (count < 2)
 if (key != NO_KEY)
       H = key;
lcd.setCursor(count, 1);lcd.write(H);
count++;
count=3;
while (count < 5)
       M = key;
lcd.setCursor(count, 1);lcd.write(M);
count++;
 while (count < 4) ;
do {
    lcd.print(key);
       S = key;
         S++;
           count++;
             if ( S % 60 == 00){
  while (count < 6) ;
do{
lcd.clear();
   while (count < 7) ;
tester telle quell sa affiche minute en H et M sa affiche comme un signe chinoi et rien en secondes meme pas de zero si japuis sur nimp quelle touche du clavier sa ffiche rien ya juste un lcd.clear qui doit sactive 1 millieme de seconde
pour l'histoire du char je pensse que le probleme vien de la comment je peut faire sans passer par un char ?
esque c'est possible ?
évite le langage SMS, merci
:slight_smile: mon but est plus de te débloquer que de te faire le code.
vais répéter mon précédent message, évite le langage SMS
après mets des serial print pour voir ce qui ressort quand tu appuie sur une touche
autre chose
while (count < 2)
while (count < 5)==> inclut le précédent while :wink:
puis
count=3;
donc le count vaut toujours 3 et donc, tes pressions pour heures ne sont prises en compte que pour minutes.
testes ce code pour vérifier tes touches
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
byte rowPins[ROWS] = {A0, A1, A2, A3}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {5, 4, 3, 2}; //connect to the column pinouts of the keypad
void setup(){
void loop(){
  if (key != NO_KEY){
    Serial.println(key);
ensuite testes ce code
#include <Wire.h>
//#include <LiquidCrystal_I2C.h>
//LiquidCrystal_I2C lcd(0x27, 20, 4); // set the LCD address to 0x27 for a 16 chars and 2 line display
#include <LiquidCrystal.h>
LiquidCrystal lcd(8,9,4,5,6,7); // pin de l'écran lcd
int count = 0 ;
char key;
//initialisation
void setup(){lcd.begin(16, 2);lcd.print("hello, world!");Serial.begin(115200);
key = 'A';Serial.println(key);
void selecttemp ()
count = 0 ;
key = '1';
while (count < 2)
 //key = keypad.getKey();
 if (key != NO_KEY)
       H = key;
Serial.print("count avant ");Serial.print(count);
count++;
key = '3';
Serial.print("count apres");Serial.print(count);
 while(1){};
count=3;
while (count < 5)
       M = key;
count++;
 while (count < 4) ;
do {
    lcd.print(key);
       S = key;
         S++;
           count++;
             if ( S % 60 == 00){
  while (count < 6) ;
do{
lcd.clear();
   while (count < 7) ;
javais tester le serial print avec hello word sa marcher nikel
je vient de tester avec le code infobarquee sa marche nikel
le code de dfgh marche pas sa affiche þOÿ|!¦ et c'est tout je peut rien faire
y a un truc que je comprent pas
''dans ton code d'origine, tu saisi des "chars" qui sont les codes ascii de ce que tu tapes
tu tapes "1", puis dans ton prg tu l'incréméntes et il vaut "2". le code ascii de "2" est "50"''
pourquoi quand je tape 1 sa vaut 2 en en char et en ascii 50 ?
c'est quoi le ascii sa sert a quoi ?
moi je pensse qua sa affiche ce que je rentre an ascii du coup aux risque de dire une connerie est que lon peut reconvertir cette valeur afficher an ascii par ex 50 pour que sa affiche 1 ?
pb de vitesse de la console ===> Serial.begin(115200)
