Hello, this is my first topic here.
I am working with the R503 fingerprint sensor and using the Adafruit Fingerprint library. My goal is to modify the library to store up to 1000 fingerprint templates.
After some research, I tried changing the uint8_t datatype to unsigned int in an attempt to increase the storage capacity, but I encountered the error: "can't store in this location."
Next, I attempted to modify the library itself by changing values like 0x01 to 0x02 and 0xFF to 0x3E8, but none of these solutions worked for me.
Library Code:
@brief Ask the sensor to store the calculated model for later matching
@param location The model location #
@returns <code>FINGERPRINT_OK</code> on success
@returns <code>FINGERPRINT_BADLOCATION</code> if the location is invalid
@returns <code>FINGERPRINT_FLASHERR</code> if the model couldn't be written
to flash memory
@returns <code>FINGERPRINT_PACKETRECIEVEERR</code> on communication error
uint8_t Adafruit_Fingerprint::storeModel(uint16_t location) {
SEND_CMD_PACKET(FINGERPRINT_STORE, 0x02, (uint8_t)(location >> 8),
(uint8_t)(location & 0xFF));
@brief Ask the sensor to load a fingerprint model from flash into buffer 1
uint8_t Adafruit_Fingerprint::loadModel(uint16_t location) {
SEND_CMD_PACKET(FINGERPRINT_LOAD, 0x02, (uint8_t)(location >> 8),
@brief Ask the sensor to transfer 256-byte fingerprint template from the
buffer to the UART
uint8_t Adafruit_Fingerprint::getModel(void) {
SEND_CMD_PACKET(FINGERPRINT_UPLOAD, 0x02);
my Arduino Code
This is an example sketch for our optical Fingerprint sensor
Designed specifically to work with the Adafruit BMP085 Breakout
----> http://www.adafruit.com/products/751
These displays use TTL Serial to communicate, 2 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include <Adafruit_Fingerprint.h>
#if (defined(__AVR__) || defined(ESP8266)) && !defined(__AVR_ATmega2560__)
// For UNO and others without hardware serial, we must use software serial...
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
// Set up the serial port to use softwareserial..
SoftwareSerial mySerial(2, 3);
#else
// On Leonardo/M0/etc, others with hardware serial, use hardware serial!
// #0 is green wire, #1 is white
#define mySerial Serial1
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
char data = '1'; //Send from C#
const int touch = 4;
uint8_t id;
while (!Serial)
; // For Yun/Leo/Micro/Zero/...
delay(100);
Serial.println("\n\nAdafruit finger detect test");
// set the data rate for the sensor serial port
finger.begin(57600);
delay(5);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1) { delay(1); }
Serial.println(F("Reading sensor parameters"));
finger.getParameters();
Serial.print(F("Status: 0x"));
Serial.println(finger.status_reg, HEX);
Serial.print(F("Sys ID: 0x"));
Serial.println(finger.system_id, HEX);
Serial.print(F("Capacity: "));
Serial.println(finger.capacity);
Serial.print(F("Security level: "));
Serial.println(finger.security_level);
Serial.print(F("Device address: "));
Serial.println(finger.device_addr, HEX);
Serial.print(F("Packet len: "));
Serial.println(finger.packet_len);
Serial.print(F("Baud rate: "));
Serial.println(finger.baud_rate);
finger.getTemplateCount();
if (finger.templateCount == 0) {
Serial.print("Sensor doesn't contain any fingerprint data. Please run the 'enroll' example.");
Serial.println("Waiting for valid finger...");
Serial.print("Sensor contains ");
Serial.print(finger.templateCount);
Serial.println(" templates");
pinMode(touch, INPUT_PULLUP);
void loop() // run over and over again
while (Serial.available() > 0) {
data = Serial.read();
if (data == '1') //New Fingerprint
finger.LEDcontrol(FINGERPRINT_LED_FLASHING, 25, FINGERPRINT_LED_PURPLE, 10);
delay(2500);
Serial.println("Ready to enroll a fingerprint!");
Serial.println("Please type in the ID # (from 1 to 250) you want to save this finger as...");
id = readnumber();
if (id == 0) { // ID #0 not allowed, try again!
return;
Serial.print("Enrolling ID #");
Serial.println(id);
while (!getFingerprintEnroll())
finger.LEDcontrol(FINGERPRINT_LED_FLASHING, 25, FINGERPRINT_LED_BLUE, 10);
delay(2500);
} else if (data == '2') //Delet Fingerprint
finger.LEDcontrol(FINGERPRINT_LED_FLASHING, 25, FINGERPRINT_LED_RED, 10);
delay(2500);
Serial.println("Please type in the ID # (from 1 to 127) you want to delete...");
uint8_t id = readnumber();
return;
Serial.print("Deleting ID #");
Serial.println(id);
deleteFingerprint(id);
} else if (data == '3') //--
finger.LEDcontrol(FINGERPRINT_LED_BREATHING, 100, FINGERPRINT_LED_RED);
delay(3000);
finger.LEDcontrol(FINGERPRINT_LED_GRADUAL_ON, 200, FINGERPRINT_LED_RED);
delay(2000);
finger.LEDcontrol(FINGERPRINT_LED_GRADUAL_OFF, 200, FINGERPRINT_LED_RED);
delay(2000);
finger.emptyDatabase();
delay(50);
//Scan Fingerprint
finger.LEDcontrol(FINGERPRINT_LED_ON, 0, FINGERPRINT_LED_BLUE);
if (digitalRead(touch) == LOW) {
Serial.println("Reading FingerPrint ....");
getFingerprintID();
//Serial.println("No finger detected");
delay(50);
//SCAN-----------------------------------------------------------------------------------
uint8_t getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
return p;
default:
Serial.println("Unknown error");
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
// OK converted!
p = finger.fingerSearch();
if (p == FINGERPRINT_OK) {
Serial.println("Found a print match!");
delay(3000);
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
Serial.println("Did not find a match");
delay(3000);
return p;
return p;
// found a match!
Serial.print("Found ID #");
Serial.print(finger.fingerID);
//Serial.print(" with confidence of ");
//Serial.println(finger.confidence);
return finger.fingerID;
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
p = finger.fingerFastSearch();
// found a match!
//NEW-----------------------------------------------------------------------------------
uint8_t readnumber(void) {
uint8_t num = 0;
while (num == 0) {
finger.LEDcontrol(FINGERPRINT_LED_FLASHING, 25, FINGERPRINT_LED_PURPLE, 25);
while (!Serial.available())
num = Serial.parseInt();
return num;
uint8_t getFingerprintEnroll() {
int p = -1;
Serial.print("Waiting for valid finger to enroll as #");
Serial.println(id);
while (p != FINGERPRINT_OK) {
switch (p) {
Serial.print(".");
default:
// OK success!
p = finger.image2Tz(1);
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
Serial.println("Remove finger");
delay(2000);
p = 0;
while (p != FINGERPRINT_NOFINGER) {
Serial.print("ID ");
Serial.println(id);
p = -1;
Serial.println("Place same finger again");
switch (p) {
Serial.print(".");
default:
// OK success!
p = finger.image2Tz(2);
switch (p) {
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
Serial.print("Creating model for #");
Serial.println(id);
p = finger.createModel();
Serial.println("Prints matched!");
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
Serial.println("Fingerprints did not match");
return p;
return p;
Serial.println(id);
p = finger.storeModel(id);
Serial.println("Stored!");
return p;
} else if (p == FINGERPRINT_BADLOCATION) {
Serial.println("Could not store in that location");
return p;
} else if (p == FINGERPRINT_FLASHERR) {
Serial.println("Error writing to flash");
return p;
return p;
delay(2000);
return true;
//Delete-----------------------------------------------------------------------------------
uint8_t deleteFingerprint(uint8_t id) {
uint8_t p = -1;
p = finger.deleteModel(id);
Serial.println("Deleted!");
Serial.println("Could not delete in that location");
Serial.print("Unknown error: 0x");
Serial.println(p, HEX);
delay(2000);
return p;
Please help
Thank you
