modified keypad lock
So I've been trying to make a keypad lock for my room but I can't figure out the code if anyone has any suggestions on how to fix the code because I keep getting error messages(I'm going to put the error messages below the code)
[#include <LiquidCrystal.h>
LiquidCrystal lcd(12,13,14,15,16); // pin conversions 12=12,13=11,14=10,15=5,16=4
#include <Servo.h>
int led1Pin = 13;  //Green LED
int led2Pin = 12;  //Blue LED
int b4Pin = 5;
int b5Pin = 6;
int b6Pin = 7;
int b7Pin = 8;
int b8Pin = 9;
int b9Pin = 10;
int inputArray(10);
int(b0Pin) = 11;
int randomArray(10);
byte combonation[] = {7,3,5,1,9,4,0};
byte userInput[7];
boolean flag = true;
  (byte = 0; n < 7 ; n++)
  if (userInput[n] ! = combination[n]
  digitalRead userInput[n] = true;
  digitalWrite led2Pin == HIGH
  else led2Pin == LOW
  lcd.clear()
  lcd.setCursor(1,0)
  lcd.print(WELCOME)
  delay(100)
  lcd.clear()
  serco.attach(17)
  servo.write(180) //test may also be 0 b/c 90 is in the middle so 180 may be left or right idk
  servo.detach(17)
    flag = false;
    if false digitalWrite led1Pin == HIGH
    else led1Pin == LOW
    lcd.clear()
    lcd.setCursor(1,0)
    lcd.print(WELCOME)
    delay(100)
    lcd.clear()
I’m sorry if I did the code wrong
ERROR messages:
Arduino: 1.6.5 (Windows 8.1), Board: “Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)”
button_game_thing:4: error: no matching function for call to ‘LiquidCrystal::LiquidCrystal(int, int, int, int, int)’
button_game_thing.ino:4:33: note: candidates are:
In file included from button_game_thing.ino:3:0:
C:\Users\siarr_000\Downloads\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\libraries\LiquidCrystal\src/LiquidCrystal.h:55:3: note: LiquidCrystal::LiquidCrystal(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)
LiquidCrystal(uint8_t rs, uint8_t enable,
C:\Users\siarr_000\Downloads\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\libraries\LiquidCrystal\src/LiquidCrystal.h:55:3: note: candidate expects 6 arguments, 5 provided
C:\Users\siarr_000\Downloads\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\libraries\LiquidCrystal\src/LiquidCrystal.h:53:3: note: LiquidCrystal::LiquidCrystal(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)
LiquidCrystal(uint8_t rs, uint8_t rw, uint8_t enable,
C:\Users\siarr_000\Downloads\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\libraries\LiquidCrystal\src/LiquidCrystal.h:53:3: note: candidate expects 7 arguments, 5 provided
C:\Users\siarr_000\Downloads\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\libraries\LiquidCrystal\src/LiquidCrystal.h:50:3: note: LiquidCrystal::LiquidCrystal(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)
C:\Users\siarr_000\Downloads\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\libraries\LiquidCrystal\src/LiquidCrystal.h:50:3: note: candidate expects 11 arguments, 5 provided
C:\Users\siarr_000\Downloads\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\libraries\LiquidCrystal\src/LiquidCrystal.h:47:3: note: LiquidCrystal::LiquidCrystal(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)
C:\Users\siarr_000\Downloads\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\libraries\LiquidCrystal\src/LiquidCrystal.h:47:3: note: candidate expects 10 arguments, 5 provided
C:\Users\siarr_000\Downloads\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\libraries\LiquidCrystal\src/LiquidCrystal.h:45:7: note: LiquidCrystal::LiquidCrystal(const LiquidCrystal&)
class LiquidCrystal : public Print {
C:\Users\siarr_000\Downloads\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\libraries\LiquidCrystal\src/LiquidCrystal.h:45:7: note: candidate expects 1 argument, 5 provided
button_game_thing.ino: In function ‘void setup()’:
button_game_thing:23: error: expected primary-expression before ‘=’ token
button_game_thing:23: error: expected ‘)’ before ‘;’ token
button_game_thing:23: error: ‘n’ was not declared in this scope
button_game_thing:23: error: expected ‘;’ before ‘)’ token
button_game_thing.ino: In function ‘void loop()’:
button_game_thing:29: error: expected ‘;’ before ‘userInput’
button_game_thing:30: error: expected ‘;’ before ‘led2Pin’
“Show verbose output during compilation”
enabled in File > Preferences.
I’m sorry about the chaotic error messages and well just the format in general. This is the first time I’m ever using any kind of forum.
You are passing 5 pin numbers when you create the lcd object. You need to pass 6, 7, 10, or 11 pin numbers.
You also seem to be using pins 12 and 13 for both LEDs and the LCD. You can't generally use a single pin for two purposes.
Are you using an Arduino UNO? If not you may find that Pins 14, 15, and 16 aren't where you think they are. Use the names A0, A1, and A2 if you want the sketch to work on both an UNO and Leonardo.
Is that all there is to the setup function?
You forgot the for at the beginning of the for loop and you didn’t give the byte variable a name. Should be
  for (byte  n = 0; n < 7 ; n++)
Then you have an empty if statement that is missing it’s final parenthesis. If those things are not equal, then do what? There’s no sense in testing all those elements if you’re not going to take any action on it.
At the beginning of loop()
n is from the setup function. It doesn't exist outside of that for loop. It is undefined here and will throw an error for trying to use a variable that doesn't exist.
You also seem to have missed out on the fact that in C all statements end with a semicolon. You have left that off of a number of lines.
You should probably study up a little on C and C++ syntax and structure and work on some basic examples before you try to write larger code. This is like trying to write a novel in Spanish when the only words you know are hola and adios.
    else led1Pin == LOW
What's that supposed to be?
