I'd like to modify this 12V 30A which uses the TL494 PWM controller IC for battery charging purposes:
There is a voltage adjust pot available which is fine but now I want to be able the current with a variable pot here is the reference schematic from it's datasheet:
I've been suggested to replace R1 with an equivalent pot but I doubt it, any suggestions? I'd be useful to get an equation along with the solution for calculating the current limit.
Pin15 of the chip has a 1volt reference, made with a voltage divider (R1, R2).
If voltage across R13 reaches that 1volt set point, current limiting kicks in.
Not hard to work out that 10A must flow through the 0.1ohm resistor for that.
So yes, if you replace the 1k resistor with a pot you should be able to adjust that set point and have adjustable current limiting.
Wise to add a (100k) bleed resistor from wiper/pin15 to ground, in case the wiper looses contact.
Leo..
You talk about a 30Amp supply, and post a 10Amp supply diagram.
Are you sure the current sense parts are the same.
Did you measure voltages with a DMM on pin15 of the chip without and with your pot added.
I assume you use all three pins of the pot, not as a 2-pin variable resistor.
Leo..
Well now is the time to get pencil and paper out and reverse engineer a schematic around the part of the circuit of the TL494 and the output terminals.
TomGeorge:
So... worth it for us to try and sort it out from what you didn't bother to tell us isn't the schematic. But not worth it for you to look at the circuit and determine what parts and values it actually uses.
polymorph:
Sorry for late answer was quite busy the last time and anyway's I was just expecting a quick answer the solution already came in.
And already got some results replacing the resistors around the pin2 of the TL494 with a 10k potentiometer. Doing this I became able to control the output voltage between 1VDC and 21VDC.
