modify madgwick filter to ignore magnetometer
Hello,
I need your help:
my MPU9250 is inside a box with many electronics (and magnetic fields). when I yaw the box the gyro shows motion but then the madgwick filter "corrects" back the yaw position because the magnetic field has moved too (and it interprets the yaw movement without magnetic movement as drift that has to be corrected, at a faster or slower rate depending on the beta parameter).
So that means I need to change the madgwick filter to use everything except for magnetometer (with the risk of yaw drift over time, that's ok)
Any idea how to do that?
Thanks!
    void madgwick(float ax, float ay, float az, float gx, float gy, float gz, float mx, float my, float mz, float* q) {
        double q0 = q[0], q1 = q[1], q2 = q[2], q3 = q[3];  // short name local variable for readability
        double recipNorm;
        double s0, s1, s2, s3;
        double qDot1, qDot2, qDot3, qDot4;
        double hx, hy;
        double _2q0mx, _2q0my, _2q0mz, _2q1mx, _2bx, _2bz, _4bx, _4bz, _2q0, _2q1, _2q2, _2q3, _2q0q2, _2q2q3, q0q0, q0q1, q0q2, q0q3, q1q1, q1q2, q1q3, q2q2, q2q3, q3q3;
        // Rate of change of quaternion from gyroscope
        qDot1 = 0.5f * (-q1 * gx - q2 * gy - q3 * gz);
        qDot2 = 0.5f * (q0 * gx + q2 * gz - q3 * gy);
        qDot3 = 0.5f * (q0 * gy - q1 * gz + q3 * gx);
        qDot4 = 0.5f * (q0 * gz + q1 * gy - q2 * gx);
        // Normalise accelerometer measurement
        double a_norm = ax * ax + ay * ay + az * az;
        if (a_norm == 0.) return;  // handle NaN
        recipNorm = 1.0 / sqrt(a_norm);
        ax *= recipNorm;
        ay *= recipNorm;
        az *= recipNorm;
        // Normalise magnetometer measurement
        double m_norm = mx * mx + my * my + mz * mz;
        if (m_norm == 0.) return;  // handle NaN
        recipNorm = 1.0 / sqrt(m_norm);
        mx *= recipNorm;
        my *= recipNorm;
        mz *= recipNorm;
        // Auxiliary variables to avoid repeated arithmetic
        _2q0mx = 2.0f * q0 * mx;
        _2q0my = 2.0f * q0 * my;
        _2q0mz = 2.0f * q0 * mz;
        _2q1mx = 2.0f * q1 * mx;
        _2q0 = 2.0f * q0;
        _2q1 = 2.0f * q1;
        _2q2 = 2.0f * q2;
        _2q3 = 2.0f * q3;
        _2q0q2 = 2.0f * q0 * q2;
        _2q2q3 = 2.0f * q2 * q3;
        q0q0 = q0 * q0;
        q0q1 = q0 * q1;
        q0q2 = q0 * q2;
        q0q3 = q0 * q3;
        q1q1 = q1 * q1;
        q1q2 = q1 * q2;
        q1q3 = q1 * q3;
        q2q2 = q2 * q2;
        q2q3 = q2 * q3;
        q3q3 = q3 * q3;
        // Reference direction of Earth's magnetic field
        hx = mx * q0q0 - _2q0my * q3 + _2q0mz * q2 + mx * q1q1 + _2q1 * my * q2 + _2q1 * mz * q3 - mx * q2q2 - mx * q3q3;
        hy = _2q0mx * q3 + my * q0q0 - _2q0mz * q1 + _2q1mx * q2 - my * q1q1 + my * q2q2 + _2q2 * mz * q3 - my * q3q3;
        _2bx = sqrt(hx * hx + hy * hy);
        _2bz = -_2q0mx * q2 + _2q0my * q1 + mz * q0q0 + _2q1mx * q3 - mz * q1q1 + _2q2 * my * q3 - mz * q2q2 + mz * q3q3;
        _4bx = 2.0f * _2bx;
        _4bz = 2.0f * _2bz;
        // Gradient decent algorithm corrective step
        s0 = -_2q2 * (2.0f * q1q3 - _2q0q2 - ax) + _2q1 * (2.0f * q0q1 + _2q2q3 - ay) - _2bz * q2 * (_2bx * (0.5f - q2q2 - q3q3) + _2bz * (q1q3 - q0q2) - mx) + (-_2bx * q3 + _2bz * q1) * (_2bx * (q1q2 - q0q3) + _2bz * (q0q1 + q2q3) - my) + _2bx * q2 * (_2bx * (q0q2 + q1q3) + _2bz * (0.5f - q1q1 - q2q2) - mz);
        s1 = _2q3 * (2.0f * q1q3 - _2q0q2 - ax) + _2q0 * (2.0f * q0q1 + _2q2q3 - ay) - 4.0f * q1 * (1 - 2.0f * q1q1 - 2.0f * q2q2 - az) + _2bz * q3 * (_2bx * (0.5f - q2q2 - q3q3) + _2bz * (q1q3 - q0q2) - mx) + (_2bx * q2 + _2bz * q0) * (_2bx * (q1q2 - q0q3) + _2bz * (q0q1 + q2q3) - my) + (_2bx * q3 - _4bz * q1) * (_2bx * (q0q2 + q1q3) + _2bz * (0.5f - q1q1 - q2q2) - mz);
        s2 = -_2q0 * (2.0f * q1q3 - _2q0q2 - ax) + _2q3 * (2.0f * q0q1 + _2q2q3 - ay) - 4.0f * q2 * (1 - 2.0f * q1q1 - 2.0f * q2q2 - az) + (-_4bx * q2 - _2bz * q0) * (_2bx * (0.5f - q2q2 - q3q3) + _2bz * (q1q3 - q0q2) - mx) + (_2bx * q1 + _2bz * q3) * (_2bx * (q1q2 - q0q3) + _2bz * (q0q1 + q2q3) - my) + (_2bx * q0 - _4bz * q2) * (_2bx * (q0q2 + q1q3) + _2bz * (0.5f - q1q1 - q2q2) - mz);
        s3 = _2q1 * (2.0f * q1q3 - _2q0q2 - ax) + _2q2 * (2.0f * q0q1 + _2q2q3 - ay) + (-_4bx * q3 + _2bz * q1) * (_2bx * (0.5f - q2q2 - q3q3) + _2bz * (q1q3 - q0q2) - mx) + (-_2bx * q0 + _2bz * q2) * (_2bx * (q1q2 - q0q3) + _2bz * (q0q1 + q2q3) - my) + _2bx * q1 * (_2bx * (q0q2 + q1q3) + _2bz * (0.5f - q1q1 - q2q2) - mz);
        recipNorm = 1.0 / sqrt(s0 * s0 + s1 * s1 + s2 * s2 + s3 * s3);  // normalise step magnitude
        s0 *= recipNorm;
        s1 *= recipNorm;
        s2 *= recipNorm;
        s3 *= recipNorm;
        // Apply feedback step
        qDot1 -= beta * s0;
        qDot2 -= beta * s1;
        qDot3 -= beta * s2;
        qDot4 -= beta * s3;
        // Integrate rate of change of quaternion to yield quaternion
        q0 += qDot1 * deltaT;
        q1 += qDot2 * deltaT;
        q2 += qDot3 * deltaT;
        q3 += qDot4 * deltaT;
        // Normalise quaternion
        recipNorm = 1.0 / sqrt(q0 * q0 + q1 * q1 + q2 * q2 + q3 * q3);
        q0 *= recipNorm;
        q1 *= recipNorm;
        q2 *= recipNorm;
        q3 *= recipNorm;
        q[0] = q0;
        q[1] = q1;
        q[2] = q2;
        q[3] = q3;
The Madgwick/Mahony IMU version of the filter works well without the magnetometer, but of course yaw is relative to the starting position, and will drift. Here is a working version for the MPU-6050. It is not so important to calibrate the accelerometer, but be SURE to calibrate the gyro.
// AD0 high = 0x69
int MPU_addr = 0x68;
// vvvvvvvvvvvvvvvvvv  VERY VERY IMPORTANT vvvvvvvvvvvvvvvvvvvvvvvvvvvvv
//These are the previously determined offsets and scale factors for accelerometer and gyro for
// a particular example of an MPU-6050. They are not correct for other examples.
//The IMU code will NOT work well or at all if these are not correct
float A_cal[6] = {265.0, -80.0, -700.0, 0.994, 1.000, 1.014}; // 0..2 offset xyz, 3..5 scale xyz
float G_off[3] = { -499.5, -17.7, -82.0}; //raw offsets, determined for gyro at rest
#define gscale ((250./32768.0)*(PI/180.0))  //gyro default 250 LSB per d/s -> rad/s
// ^^^^^^^^^^^^^^^^^^^ VERY VERY IMPORTANT ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
// GLOBALLY DECLARED, required for Mahony filter
// vector to hold quaternion
float q[4] = {1.0, 0.0, 0.0, 0.0};
// Free parameters in the Mahony filter and fusion scheme,
// Kp for proportional feedback, Ki for integral
float Kp = 30.0;
float Ki = 0.0;
// with MPU-9250, angles start oscillating at Kp=40. Ki does not seem to help and is not required.
// with MPU-6050, some instability observed at Kp=100 Now set to 30.
// char s[60]; //snprintf buffer, if needed
// globals for AHRS loop timing
unsigned long now_ms, last_ms = 0; //millis() timers
// print interval
unsigned long print_ms = 200; //print angles every "print_ms" milliseconds
float yaw, pitch, roll; //Euler angle output
  Wire.begin();
  Serial.println("starting");
  // initialize sensor
  // defaults for gyro and accel sensitivity are 250 dps and +/- 2 g
  Wire.beginTransmission(MPU_addr);
  Wire.write(0x6B);  // PWR_MGMT_1 register
  Wire.write(0);     // set to zero (wakes up the MPU-6050)
  Wire.endTransmission(true);
// AHRS loop
  static float deltat = 0;  //loop time in seconds
  static unsigned long now = 0, last = 0; //micros() timers
  //raw data
  int16_t ax, ay, az;
  int16_t gx, gy, gz;
  int16_t Tmp; //temperature
  //scaled data as vector
  float Axyz[3];
  float Gxyz[3];
  Wire.write(0x3B);  // starting with register 0x3B (ACCEL_XOUT_H)
  Wire.endTransmission(false);
  Wire.requestFrom(MPU_addr, 14, true); // request a total of 14 registers
  int t = Wire.read() << 8;
  ax = t | Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
  ay = t | Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
  az = t | Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
  Tmp = t | Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
  gx = t | Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
  gy = t | Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
  gz = t | Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
  Axyz[0] = (float) ax;
  Axyz[1] = (float) ay;
  Axyz[2] = (float) az;
  //apply offsets and scale factors from Magneto
  for (int i = 0; i < 3; i++) Axyz[i] = (Axyz[i] - A_cal[i]) * A_cal[i + 3];
  Gxyz[0] = ((float) gx - G_off[0]) * gscale; //250 LSB(d/s) default to radians/s
  Gxyz[1] = ((float) gy - G_off[1]) * gscale;
  Gxyz[2] = ((float) gz - G_off[2]) * gscale;
  //  snprintf(s,sizeof(s),"mpu raw %d,%d,%d,%d,%d,%d",ax,ay,az,gx,gy,gz);
  //  Serial.println(s);
  now = micros();
  deltat = (now - last) * 1.0e-6; //seconds since last update
  last = now;
  Mahony_update(Axyz[0], Axyz[1], Axyz[2], Gxyz[0], Gxyz[1], Gxyz[2], deltat);
  // Compute Tait-Bryan angles.
  // In this coordinate system, the positive Z-axis is up, X points north and Y west.
  // Yaw is the angle between Sensor X-axis and Earth magnetic North
  // (or true North if corrected for local declination, looking down on the sensor
  // positive yaw is counterclockwise, which is not conventional for NED navigation.
  // Pitch is angle between sensor X-axis and Earth ground plane, toward the
  // Earth is positive, up toward the sky is negative. Roll is angle between
  // sensor y-axis and Earth ground plane, Y-axis up is positive roll. These
  // arise from the definition of the homogeneous rotation matrix constructed
  // from quaternions. Tait-Bryan angles as well as Euler angles are
  // non-commutative; that is, the get the correct orientation the rotations
  // must be applied in the correct order which for this configuration is yaw,
  // pitch, and then roll.
  // http://en.wikipedia.org/wiki/Conversion_between_quaternions_and_Euler_angles
  // which has additional links.
  roll  = atan2((q[0] * q[1] + q[2] * q[3]), 0.5 - (q[1] * q[1] + q[2] * q[2]));
  pitch = asin(2.0 * (q[0] * q[2] - q[1] * q[3]));
  //conventional yaw increases clockwise from North. Not that the MPU-6050 knows where North is.
  yaw   = -atan2((q[1] * q[2] + q[0] * q[3]), 0.5 - (q[2] * q[2] + q[3] * q[3]));
  // to degrees
  yaw   *= 180.0 / PI;
  if (yaw < 0) yaw += 360.0; //compass circle
  pitch *= 180.0 / PI;
  roll *= 180.0 / PI;
  now_ms = millis(); //time to print?
  if (now_ms - last_ms >= print_ms) {
    last_ms = now_ms;
    // print angles for serial plotter...
    //  Serial.print("ypr ");
    Serial.print(yaw, 0);
    Serial.print(", ");
    Serial.print(pitch, 0);
    Serial.print(", ");
    Serial.println(roll, 0);
// Mahony scheme uses proportional and integral filtering on
// the error between estimated reference vector (gravity) and measured one.
// Madgwick's implementation of Mayhony's AHRS algorithm.
// See: http://www.x-io.co.uk/node/8#open_source_ahrs_and_imu_algorithms
// Date      Author      Notes
// 29/09/2011 SOH Madgwick    Initial release
// 02/10/2011 SOH Madgwick  Optimised for reduced CPU load
// last update 07/09/2020 SJR minor edits
// IMU algorithm update
void Mahony_update(float ax, float ay, float az, float gx, float gy, float gz, float deltat) {
  float recipNorm;
  float vx, vy, vz;
  float ex, ey, ez;  //error terms
  float qa, qb, qc;
  static float ix = 0.0, iy = 0.0, iz = 0.0;  //integral feedback terms
  float tmp;
  // Compute feedback only if accelerometer measurement valid (avoids NaN in accelerometer normalisation)
  tmp = ax * ax + ay * ay + az * az;
 if (tmp > 0.0)
    // Normalise accelerometer (assumed to measure the direction of gravity in body frame)
    recipNorm = 1.0 / sqrt(tmp);
    ax *= recipNorm;
    ay *= recipNorm;
    az *= recipNorm;
    // Estimated direction of gravity in the body frame (factor of two divided out)
    vx = q[1] * q[3] - q[0] * q[2];
    vy = q[0] * q[1] + q[2] * q[3];
    vz = q[0] * q[0] - 0.5f + q[3] * q[3];
    // Error is cross product between estimated and measured direction of gravity in body frame
    // (half the actual magnitude)
    ex = (ay * vz - az * vy);
    ey = (az * vx - ax * vz);
    ez = (ax * vy - ay * vx);
    // Compute and apply to gyro term the integral feedback, if enabled
    if (Ki > 0.0f) {
      ix += Ki * ex * deltat;  // integral error scaled by Ki
      iy += Ki * ey * deltat;
      iz += Ki * ez * deltat;
      gx += ix;  // apply integral feedback
      gy += iy;
      gz += iz;
    // Apply proportional feedback to gyro term
    gx += Kp * ex;
    gy += Kp * ey;
    gz += Kp * ez;
  // Integrate rate of change of quaternion, q cross gyro term
  deltat = 0.5 * deltat;
  gx *= deltat;   // pre-multiply common factors
  gy *= deltat;
  gz *= deltat;
  qa = q[0];
  qb = q[1];
  qc = q[2];
  q[0] += (-qb * gx - qc * gy - q[3] * gz);
  q[1] += (qa * gx + qc * gz - q[3] * gy);
  q[2] += (qa * gy - qb * gz + q[3] * gx);
  q[3] += (qa * gz + qb * gy - qc * gx);
  // renormalise quaternion
  recipNorm = 1.0 / sqrt(q[0] * q[0] + q[1] * q[1] + q[2] * q[2] + q[3] * q[3]);
  q[0] = q[0] * recipNorm;
  q[1] = q[1] * recipNorm;
  q[2] = q[2] * recipNorm;
  q[3] = q[3] * recipNorm;
This is Mahony, I was trying to get Madgwick without magneto
Why do you care? The two filters are not significantly different with respect to 3D angle accuracy, but the Mahony filter is smaller and faster.
