I am using mpu6050 with arduino and oled to display titled anglation
here the code and it is working so good
//Import all required libraries
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
const int MPU6050_addr = 0x68;
int16_t axis_X,axis_Y,axis_Z;
int minVal=265;
int maxVal=402;
double x;
double y;
double z;
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET 4 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { //Ive changed the address //already chill
Serial.println(F("SSD1306 allocation failed"));
for (;;); // Don't proceed, loop forever
// Show initial display buffer contents on the screen --
// the library initializes this with an Adafruit splash screen.
display.display();
delay(2000); // Pause for 2 seconds
// Clear the buffer
// Show the display buffer on the screen. You MUST call display() after
// drawing commands to make them visible on screen!
Wire.begin();
Wire.beginTransmission(MPU6050_addr);
Wire.write(0x6B);
Wire.write(0);
Wire.endTransmission(true);
display.clearDisplay();
display.setTextSize(1.5);
display.setTextColor(WHITE);
display.setRotation(0);
Wire.write(0x3B);
Wire.endTransmission(false);
Wire.requestFrom(MPU6050_addr, 14, true);
axis_X = Wire.read() << 8 | Wire.read();
axis_Y = Wire.read() << 8 | Wire.read();
axis_Z = Wire.read() << 8 | Wire.read();
int xAng = map(axis_X,minVal,maxVal,-90,90);
int yAng = map(axis_Y,minVal,maxVal,-90,90);
int zAng = map(axis_Z,minVal,maxVal,-90,90);
x= RAD_TO_DEG * (atan2(-yAng, -zAng)+PI);
y= RAD_TO_DEG * (atan2(-xAng, -zAng)+PI);
z= RAD_TO_DEG * (atan2(-yAng, -xAng)+PI);
display.setCursor(0, 0);
display.print("X axis = ");
display.print(x);
display.print("\n");
display.print("y axis = ");
display.print(y);
display.print("z axis = ");
display.print(z);
display.println("");
display.display();
delay(200); // Pause for 2 seconds
but i need to remove the two number after (.) (i marked it with red circle), how can i do this?
