Modify sketch from using keypad to regular buttons
Hello all.
I'm trying to modify a skecth to use in an Airsoft game device. I got the source code from the web, it's been used an copied over many times before. I myself have used it to make an entire device with different game types according to video guides and tutorials.
I now want to modify this code to use different hardware and code. Specifically, I want to use only one of the game modes and change the input device from a 4x4 keypad to 2 simple push buttons.
So far I have the game mode part almost done, but I haven't been able to change the input method from the key pad to the push buttons.
The original sketch uses the keypad library, which has the keypad.getKey function that monitors for key presses. How can I achieve that with the 2 seperate push buttons? I need each button to do a different function.
Here is the code I have so far:
#include <Wire.h>
LiquidCrystal_I2C lcd(0x3f,16,2);
//leds
const int REDLEDS = 15;     //pin D8
const int GREENLED = 13;    //pin D7
//TIME INTS
int GAMEHOURS = 4;
int GAMEMINUTES = 30;
int BOMBMINUTES = 5;
int ACTIVATESECONDS = 8;
boolean endGame = false;
boolean doStatus = false; //for DEmolition
boolean start = true;
boolean defusing;
boolean cancelando;
// SOUND TONES
boolean soundEnable = true;
int tonepin = 12;                // Pin D6 for the buzzer
int alarmTone1 = 700;
int alarmTone2 = 2600;
int activeTone = 1330;
int errorTone = 100;
unsigned long iTime;
unsigned long timeCalcVar;
unsigned long redTime;
unsigned long greenTime;
unsigned long iZoneTime;//initial time for zone
byte team=0; // 0 = neutral, 1 = green team, 2 = red team
void setup(){
  lcd.begin(16, 2);
  lcd.setCursor(3,0);
  tone(tonepin,2400,30);
  lcd.print("LOBOS DEL");// you can add your team name or someting cool
  lcd.setCursor(4,1);
  lcd.print("NORTE");// you can add your team name or someting cool
  //PinModes
  pinMode(GREENLED, OUTPUT);
  pinMode(REDLED, OUTPUT);
//  pinMode(RELAYPIN, OUTPUT);
  // CONFIGURE THE BARS OF PROGRESS BAR
  byte bar1[8] = {
    B10000,
    B10000,
    B10000,
    B10000,
    B10000,
    B10000,
    B10000,
    B10000,
  byte bar2[8] = {
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
    B11000,
  byte bar3[8] = {
    B11100,
    B11100,
    B11100,
    B11100,
    B11100,
    B11100,
    B11100,
    B11100,
  byte bar4[8] = {
    B11110,
    B11110,
    B11110,
    B11110,
    B11110,
    B11110,
    B11110,
    B11110,
  byte bar5[8] = {
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
    B11111,
  byte up[8] = {
    B00000,
    B00100,
    B01110,
    B11111,
    B11111,
    B00000,
    B00000,
  byte down[8] = {
    B00000,
    B00000,
    B11111,
    B11111,
    B01110,
    B00100,
    B00000,
  lcd.createChar(0,bar1);
  lcd.createChar(1,bar2);
  lcd.createChar(2,bar3);
  lcd.createChar(3,bar4);
  lcd.createChar(4,bar5);
  lcd.createChar(5,up);
  lcd.createChar(6,down);
void loop(){
  //SETUP INITIAL TIME
  int minutos = GAMEMINUTES-1;
  boolean showGameTime=true;
  unsigned long a;
  unsigned long iTime=millis(); //  initialTime in millisec
  unsigned long aTime;
  team=0;
  iZoneTime=0;
  aTime=0;
  redTime=0;
  greenTime=0;
  int largoTono = 50;
  a=millis();
  //Starting Game Code
  while(1)  // this is the important code, is a little messy but works good.
    if(endGame){
      gameOver();
    keypad.getKey();
    aTime=millis()- iTime;
    //Code for led blinking
    timeCalcVar=(millis()- iTime)%1000;
    if(timeCalcVar >= 0 && timeCalcVar <= 40)
      if(team==1)digitalWrite(GREENLED, HIGH);
      if(team==2)digitalWrite(REDLED, HIGH);
    if(timeCalcVar >= 50 && timeCalcVar <= 100)
      if(team==1)digitalWrite(GREENLED, LOW);
      if(team==2)digitalWrite(REDLED, LOW);
    // Sound!!! same as Destroy
    if(timeCalcVar >= 0 && timeCalcVar <= 40 && soundEnable)tone(tonepin,activeTone,largoTono);
    if(timeCalcVar >= 245 && timeCalcVar <= 255 && minutos-aTime/60000<2 && soundEnable)tone(tonepin,activeTone,largoTono);
    if(timeCalcVar >= 495 && timeCalcVar <= 510 && minutos-aTime/60000<4 && soundEnable)tone(tonepin,activeTone,largoTono);
    if(timeCalcVar >= 745 && timeCalcVar <= 760 && minutos-aTime/60000<2 && soundEnable)tone(tonepin,activeTone,largoTono);
    //Help to count 3 secs
    if(a+2000<millis()){
      a=millis();
      showGameTime=!showGameTime;
      cls();
    //THE NEXT TO METHODS SHOW "GAME TIME" AND "CONTROLED ZONE TIME" IT SHOWS 2 AND 2 SEC EACH
    if(showGameTime){ //THE SECOND IS /2
      lcd.setCursor(3,0);
      lcd.print("GAME TIME");
      lcd.setCursor(3,1);
      printTime(minutos, aTime);
    else if (!showGameTime){
      lcd.setCursor(2,0);
      if(team == 0)lcd.print("NEUTRAL ZONE");
      if(team == 1)lcd.print(" GREEN ZONE");
      if(team == 2)lcd.print("  RED ZONE");
      if(team>0){
        lcd.setCursor(3,1);
        printTimeDom(millis()-iZoneTime,true);
    //###########################CHECKINGS##################
    //Check If Game End
    if(minutos-aTime/60000==0 && 59-((aTime/1000)%60)==0)
      gameOver();
    //Check If IS neutral
    while((defusing || cancelando) && team > 0)
      cls();
      if(team>0)lcd.print("NEUTRALIZING...");
      lcd.setCursor(0,1);
      unsigned int percent=0;
      unsigned long xTime=millis(); //start disabling time
      while(defusing || cancelando)
        //check if game time runs out during the disabling
        aTime= millis()- iTime;
        if((minutos-aTime/60000==0 && 59-((aTime/1000)%60)==0) || minutos-aTime/60000>4000000000){
          endGame = true;
        keypad.getKey();
        timeCalcVar = (millis()- xTime)%1000;
        if( timeCalcVar >= 0 && timeCalcVar <= 20)
          if(soundEnable)tone(tonepin,alarmTone1,200);
        if(timeCalcVar >= 480 && timeCalcVar <= 500)
          if(soundEnable)tone(tonepin,alarmTone2,200);
        unsigned long seconds= millis() - xTime;
        percent = (seconds)/(ACTIVATESECONDS*10);
        drawBar(percent);
        if(percent >= 100)
          if(team==1){
            greenTime+=millis()-iZoneTime;
            iZoneTime=0;
          if(team==2){
            redTime+=millis()-iZoneTime;
            iZoneTime=0;
          team=0;
      cls();
    //Capturing red
    while(defusing && team == 0 )
      cls();
      if(team==0)lcd.print(" CAPTURING ZONE");
      lcd.setCursor(0,1);
      while(defusing)
        keypad.getKey();
          endGame = true;
        drawBar(percent);
        if(percent >= 100)
          team=2;
          iZoneTime=millis();
      cls();
    //getting to green zone
    while(cancelando && team == 0 )
      cls();
      if(team==0)lcd.print("CAPTURANDO ZONA");
      lcd.setCursor(0,1);
      while(cancelando)
        keypad.getKey();
          endGame = true;
        drawBar(percent);
        if(percent >= 100)
          team=1;
          iZoneTime=millis();
      cls();
void gameOver(){
  if(team==1)greenTime+=millis()-iZoneTime;
  if(team==2)redTime+=millis()-iZoneTime;
  while(!defusing){
    keypad.getKey();
    if(defusing){
      keypad.getKey();
    lcd.clear();
    lcd.setCursor(3,0);
    lcd.print("TIME OVER!");
    lcd.setCursor(0,1);
    //check who team win the base
    if(greenTime>redTime){
      //greenteam wins
      lcd.print(" GREEN TEAM WINS");
    else{
      //redteam wins
      lcd.print("  RED TEAM WINS");
    delay(3000);
    keypad.getKey();
    if(defusing){
      keypad.getKey();
    cls();
    lcd.print("Red Time:");
    lcd.setCursor(5,1);
    printTimeDom(redTime,false);
    delay(3000);
    keypad.getKey();
    if(defusing){
    cls();
    lcd.print("Green Time:");
    lcd.setCursor(5,1);
    printTimeDom(greenTime,false);
    delay(3000);
    keypad.getKey();
    if(defusing){
      keypad.getKey();
Sorry if the code is long and messy. It is what I originally found online and have just modified a bit as best I can.
15 posts were merged into an existing topic: Help! "Error compiling for board" msg
