Modify sketch to accommodate second light sensor
I need help with this code, originally contributed by Rob Tilllaart, to add a second TSL235 light sensor. There is no need or a datasheet for the sensor - the TSL235 is just a square wave source. In the program, digital pin 2 is counting rising edges of a square wave signal input for one second, with attachInterrupt, then printing the counts as Hz. The second TSL235 will use digital pin 3 the same way. The goal is to have the outputs from both sensors read to serial output. Any help much appreciated.
Thanks, David
 *    FILE: demo01.pde
 *  AUTHOR: Rob Tillaart
 *    DATE: 2011 05 16
 * PURPOSE: prototype TSL235R monitoring
 * Digital Pin layout ARDUINO
 *  2     IRQ 0    - to TSL235R
 * PIN 1 - GND
 * PIN 2 - VDD - 5V
 * PIN 3 - SIGNAL
volatile unsigned long cnt = 0;
unsigned long oldcnt = 0;
unsigned long t = 0;
unsigned long last;
void irq1()
  cnt++;
// SETUP
  Serial.println("START");
  pinMode(2, INPUT);
  digitalWrite(2, HIGH);
  attachInterrupt(0, irq1, RISING);
// MAIN LOOP
  if (millis() - last > 1000)
    last = millis();
    t = cnt;
    unsigned long hz = t - oldcnt;
    Serial.print("FREQ: ");
    Serial.print(hz);
    Serial.print("\t = ");
    Serial.print((hz+50)/100);  // +50 == rounding last digit
    Serial.println(" mW/m2");
    oldcnt = t;
// END OF FILE
Start here
Then here
Hint:
volatile unsigned long cnt[2];
unsigned long oldcnt [2];
void irq0()
  cnt[0]++;
void irq1()
  cnt[1]++;
Thanks for hint. This code returns "0" for FREQ1:
 *    FILE: demo01.pde
 *    DATE: 2011 05 16
 * PIN 1 - GND
 * PIN 2 - VDD - 5V
 * PIN 3 - SIGNAL
unsigned long last;
volatile unsigned long cnt2 = 0;
unsigned long oldcnt2 = 0;
unsigned long t2 = 0;
unsigned long last2;
void irq1()
  cnt++;
void irq2()
  cnt2++;
// SETUP
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  digitalWrite(3, HIGH);
  attachInterrupt(0, irq2, RISING);
// MAIN LOOP
    last = millis();
    t = cnt;
    t2 = cnt2;
    unsigned long hz2 = t2 - oldcnt2;
    Serial.print("FREQ1: ");
    Serial.print(hz);
    Serial.print("FREQ2: ");
    Serial.print(hz2);
    Serial.print((hz2+50)/100);  // +50 == rounding last digit
    oldcnt = t;
    oldcnt2 = t2;
// END OF FILE
You can't put attach two ISRs on the same interrupt source like that.
