Modify the program "Blink without Delay" to count down and up
Hello,
I’m sorry if someone has already asked a similar question.
I’m currently working on a strobescope program using the millis() function.
The reason I’m using millis() is because I want to have several LEDs flashing simultaneously in different frequencies(this part wasn’t so hard).
The program below is a simplified version of the program I’m working on, which is based on the “Blink without Delay” program introduced as an example in a tutorial. http://arduino.cc/en/Tutorial/BlinkWithoutDelay
What I want to do in the version below is to have the blinking frequency go down(or up) after going up(or down).
This program is partially working, because the frequency goes down once, and then goes back up once, but after that the frequency keeps on going down.
/* Modified "Blink without Delay" */
// constants won't change. Used here to
// set pin numbers:
const int ledPin =  13;      // the number of the LED pin
// Variables will change:
int ledState = LOW;             // ledState used to set the LED
long previousMillis = 0;        // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 100;           // interval at which to blink (milliseconds)
int i = 0;    //using to count
int up = 1;    //using as a flag to indicate if the program to count up or down
  // set the digital pin as output:
  pinMode(ledPin, OUTPUT);
  if(currentMillis - previousMillis > interval && up == 1) {
    // save the last time you blinked the LED
    i = i + 5;
    interval = interval + i;
    digitalWrite(ledPin, HIGH);
    if(interval >= 300)up = 0;
    if(currentMillis - previousMillis > interval && up == 0) {
    i = i - 5;
    interval = interval - i;
     if(interval <= 100)up = 1;
  if(currentMillis - previousMillis > 5)digitalWrite(ledPin, LOW);    //turn LED off right after it's turned on
To have the program decide if it has to count up or down, I’m using the integer “up” and am switching between 1 or 0. If “up” is 1, the code
i = i + 5;
is chosen, and if up is 0, the program
i = i - 5;
is chosen.
In my understanding, this program should continuously make the frequency go up and down again and again, but for some reason it only does that once and keeps on going down after that.
Can anyone explain why it does so, and are there any ways to solve that problem?
Thank you very much for your attention.
Best,
mkto
You don't need to test the time twice. Try something like this (assumes you want to change by 20 each step)
// at the top of the program
  int i = 20;
  unsigned long interval = 100
 // in loop()
  if(currentMillis - previousMillis > interval ) {
    previousMillis += interval;  // keeps the timing tighter
    interval = interval + i; // if i is negative this will reduce
    digitalWrite(ledPin, ! digitalRead(ledPin); // toggles the pin
    if(interval > 300 || interval < 100) {
        i = - i;   // changes the value from + to - etc
...R
    i = i - 5;
What will happen to the value of interval when i goes negative ?
Try printing i and interval just before the test for the value of interval
Ok I understand and fixed the program to
    interval = interval + 20;
    interval = interval - 20;
     if(interval <= 90)up = 1;
and it seems to be working.
Thanks again!
mkto
