WARNING: library ESP32WebServer-master claims to run on (ESP32) architecture(s) and may be incompatible with your current board which runs on (esp32) architecture(s).
C:\Users\Pip\AppData\Local\Temp\arduino_modified_sketch_270455\sketch_aug12a.ino: In function ‘void initialize_wifi()’:
sketch_aug12a:114: error: C99 designator ‘ssid’ outside aggregate initializer
sketch_aug12a:114: error: C99 designator ‘password’ outside aggregate initializer
C:\Users\Pip\AppData\Local\Temp\arduino_modified_sketch_270455\sketch_aug12a.ino:114:5: sorry, unimplemented: non-trivial designated initializers not supported
sketch_aug12a:128: error: C99 designator ‘ssid’ outside aggregate initializer
sketch_aug12a:128: error: C99 designator ‘password’ outside aggregate initializer
C:\Users\Pip\AppData\Local\Temp\arduino_modified_sketch_270455\sketch_aug12a.ino:128:5: sorry, unimplemented: non-trivial designated initializers not supported
C:\Users\Pip\AppData\Local\Temp\arduino_modified_sketch_270455\sketch_aug12a.ino: In function ‘int set_relay_state(int, uint32_t)’:
sketch_aug12a:137: error: invalid conversion from ‘int’ to ‘gpio_num_t’ [-fpermissive]
gpio_set_level(cntrl_pins[relay], level);
In file included from C:\Users\Pip\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0/tools/sdk/include/esp32/esp_sleep.h:19:0,
from C:\Users\Pip\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0/tools/sdk/include/esp32/esp_system.h:21,
from C:\Users\Pip\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0/tools/sdk/include/freertos/freertos/portable.h:126,
from C:\Users\Pip\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0/tools/sdk/include/freertos/freertos/FreeRTOS.h:105,
from C:\Users\Pip\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0\cores\esp32/Arduino.h:32,
from sketch\sketch_aug12a.ino.cpp:1:
C:\Users\Pip\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0/tools/sdk/include/driver/driver/gpio.h:315:11: note: initializing argument 1 of ‘esp_err_t gpio_set_level(gpio_num_t, uint32_t)’
esp_err_t gpio_set_level(gpio_num_t gpio_num, uint32_t level);
C:\Users\Pip\AppData\Local\Temp\arduino_modified_sketch_270455\sketch_aug12a.ino: In function ‘int app_main()’:
sketch_aug12a:303: error: invalid conversion from ‘int’ to ‘gpio_num_t’ [-fpermissive]
gpio_set_direction(cntrl_pins*, GPIO_MODE_OUTPUT);*
- from C:\Users\Pip\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0/tools/sdk/include/esp32/esp_system.h:21,*
- from C:\Users\Pip\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0/tools/sdk/include/freertos/freertos/portable.h:126,*
- from C:\Users\Pip\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0/tools/sdk/include/freertos/freertos/FreeRTOS.h:105,*
- from C:\Users\Pip\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0\cores\esp32/Arduino.h:32,*
- from sketch\sketch_aug12a.ino.cpp:1:*
C:\Users\Pip\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0/tools/sdk/include/driver/driver/gpio.h:344:11: note: initializing argument 1 of ‘esp_err_t gpio_set_direction(gpio_num_t, gpio_mode_t)’
esp_err_t gpio_set_direction(gpio_num_t gpio_num, gpio_mode_t mode);
sketch_aug12a:304: error: invalid conversion from ‘int’ to ‘gpio_num_t’ [-fpermissive]
gpio_set_level(cntrl_pins*, 0);
_ ^_
Multiple libraries were found for “WiFiServer.h”
Used: C:\Users\Pip\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0\libraries\WiFi
Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
_ from C:\Users\Pip\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0/tools/sdk/include/freertos/freertos/portable.h:126,_
_ from C:\Users\Pip\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0/tools/sdk/include/freertos/freertos/FreeRTOS.h:105,_
_ from C:\Users\Pip\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0\cores\esp32/Arduino.h:32,_
_ ^_
sketch_aug12a:308: error: invalid conversion from 'void ()()’ to ‘TaskFunction_t {aka void ()(void)}’ [-fpermissive]
* xTaskCreate(&generate_json, “json”, 2048, NULL, 5, NULL);
_ ^_
In file included from C:\Users\Pip\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0\cores\esp32/Arduino.h:33:0,
C:\Users\Pip\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.0/tools/sdk/include/freertos/freertos/task.h:430:37: note: initializing argument 1 of 'BaseType_t xTaskCreate(TaskFunction_t, const char, uint32_t, void*, UBaseType_t, void**)’
* static inline IRAM_ATTR BaseType_t xTaskCreate(
_ ^_
exit status 1
I tried to program the esp with your modified lines but this happens. I changed between 4 esp32 board but the same happens.
Added a picture of the problem
_*_
