Hello!
I'm a Design Teacher, but an Arduino coding novice. I've done a few basic Arduino projects (LEDs, Neopixels, buttons, etc), but I get a little lost beyond the basics. I have a "Bare Conductive Board" (basically a Leonardo board, with on-board support for their conductive pads).
One of the sample sketches is "Touch_MP3.ino", which plays an MP3 when a pad is triggered. Unless I misunderstand, it plays the MP3 with the same integer label as the pad. What I would like to do is modify the code so I could select a "bank" of sounds by hitting a button to switch the banks. Still only 12 at a time, since there are only 12 conductive pads on the board, but load a different set of sounds from the SD card.
Bare Conductive Touch MP3 player
Touch_MP3.ino - touch triggered MP3 playback
You need twelve MP3 files named TRACK000.mp3 to TRACK011.mp3 in the root of the
microSD card.
When you touch electrode E0, TRACK000.mp3 will play. When you touch electrode
E1, TRACK001.mp3 will play, and so on.
SD card
TRACK000.mp3
TRACK001.mp3
TRACK002.mp3
TRACK003.mp3
TRACK004.mp3
TRACK005.mp3
TRACK006.mp3
TRACK007.mp3
TRACK008.mp3
TRACK009.mp3
TRACK010.mp3
TRACK011.mp3
Based on code by Jim Lindblom and plenty of inspiration from the Freescale
Semiconductor datasheets and application notes.
Bare Conductive code written by Stefan Dzisiewski-Smith, Peter Krige, Pascal
Loose
This work is licensed under a MIT license https://opensource.org/licenses/MIT
Copyright (c) 2016, Bare Conductive
// compiler error handling
#include "Compiler_Errors.h"
// touch includes
#include <MPR121.h>
#include <MPR121_Datastream.h>
#include <Wire.h>
// MP3 includes
#include <SPI.h>
#include <SdFat.h>
#include <FreeStack.h>
#include <SFEMP3Shield.h>
// touch constants
const uint32_t BAUD_RATE = 115200;
const uint8_t MPR121_ADDR = 0x5C;
const uint8_t MPR121_INT = 4;
// serial monitor behaviour constants
const bool WAIT_FOR_SERIAL = false;
// MPR121 datastream behaviour constants
const bool MPR121_DATASTREAM_ENABLE = false;
// MP3 variables
uint8_t result;
uint8_t lastPlayed = 0;
// MP3 constants
SFEMP3Shield MP3player;
// MP3 behaviour constants
const bool REPLAY_MODE = true; // by default, touching an electrode repeatedly will
// play the track again from the start each time
// if you set this to false, repeatedly touching an
// electrode will stop the track if it is already
// playing, or play it from the start if it is not
// SD card instantiation
SdFat sd;
Serial.begin(BAUD_RATE);
pinMode(LED_BUILTIN, OUTPUT);
if (WAIT_FOR_SERIAL) {
while (!Serial);
if (!sd.begin(SD_SEL, SPI_HALF_SPEED)) {
sd.initErrorHalt();
if (!MPR121.begin(MPR121_ADDR)) {
Serial.println("error setting up MPR121");
switch (MPR121.getError()) {
case NO_ERROR:
Serial.println("no error");
case ADDRESS_UNKNOWN:
Serial.println("incorrect address");
case READBACK_FAIL:
Serial.println("readback failure");
case OVERCURRENT_FLAG:
Serial.println("overcurrent on REXT pin");
case OUT_OF_RANGE:
Serial.println("electrode out of range");
case NOT_INITED:
Serial.println("not initialised");
default:
Serial.println("unknown error");
while (1);
MPR121.setInterruptPin(MPR121_INT);
if (MPR121_DATASTREAM_ENABLE) {
MPR121.restoreSavedThresholds();
MPR121_Datastream.begin(&Serial);
MPR121.setTouchThreshold(40);
MPR121.setReleaseThreshold(20);
MPR121.setFFI(FFI_10);
MPR121.setSFI(SFI_10);
MPR121.setGlobalCDT(CDT_4US); // reasonable for larger capacitances
digitalWrite(LED_BUILTIN, HIGH); // switch on user LED while auto calibrating electrodes
MPR121.autoSetElectrodes(); // autoset all electrode settings
digitalWrite(LED_BUILTIN, LOW);
result = MP3player.begin();
MP3player.setVolume(10, 10);
if (result != 0) {
Serial.print("Error code: ");
Serial.print(result);
Serial.println(" when trying to start MP3 player");
MPR121.updateAll();
// only make an action if we have one or fewer pins touched
// ignore multiple touches
if (MPR121.getNumTouches() <= 1) {
for (int i=0; i < 12; i++) { // check which electrodes were pressed
if (MPR121.isNewTouch(i)) {
if (!MPR121_DATASTREAM_ENABLE) {
Serial.print("pin ");
Serial.print(i);
Serial.println(" was just touched");
if (i <= 11 && i >= 0) {
if (MP3player.isPlaying()) {
if (lastPlayed == i && !REPLAY_MODE) {
// if we're already playing the requested track, stop it
// (but only if we're not in REPLAY_MODE)
MP3player.stopTrack();
Serial.print("stopping track ");
Serial.println(i-0);
// if we're already playing a different track (or we're in
// REPLAY_MODE), stop and play the newly requested one
MP3player.playTrack(i-0);
Serial.print("playing track ");
lastPlayed = i;
// if we're playing nothing, play the requested track
lastPlayed = i;
if (MPR121.isNewRelease(i)) {
Serial.print(i);
Serial.println(" is no longer being touched");
MPR121_Datastream.update();
I'd like some advice on what the best approach would be, to narrow down my research/experimentation.
To begin with, I suppose I need to establish a variable for "BankNumber", switchable with a button press. I think I can handle that.Beyond that, I am considering ...
- Using folders? Keep the file names the same, but somehow have the MP3 player switch to/look in the folder which corresponds to the BankNumber variable?
- Identify different ranges? Something like: if bank zero, play TRACK000.mp3 - TRACK011.mp3, if bank 1 play TRACK012.mp3 - TRACK023.mp3, etc.
- Rename the files themselves depending on the bank chosen? Or include a prefix or other identifier in the filename which identifies the bank? Then somehow associate A_Track000.mp3 to the first pad when Bank 1 is selected and B_Track000.mp3 when the second bank is selected?
Any advice you can give me on the easiest/best approach to accomplishing this (for a novice) would be much appreciated. Thanks!
