Modifying Adafruit 16-channel PWM & Servo Driver test code
Good morning, everyone!
I'm still fairly new to Arduino and just got a grasp of the basics of coding. I'm working on a project that requires 4 micro servos (using the TowerPro SG92R from Adafruit) to move at once in different directions and with a solenoid water valve trigger.
As far as the servos go, I've temporarily wired everything correctly (I want to wait on soldering just in case) and successfully uploaded the Adafruit 16-channel PWM & Servo Driver test code. However, I'm not quite sure how to modify the code to get the servos moving at the same time and slightly faster. And then, to take it a step further, to add a button controlled solenoid water valve.
I've tried to go line by line to really understand what I'm looking at and why the numbers are what they are, but I'm coming up with a blank. My first step was to adjust the delays, but that didn't seem to change anything. Would anyone be able to help me understand this code and where I can adjust?
Thank you in advance!
This is an example for our Adafruit 16-channel PWM & Servo driver
Servo test - this will drive 8 servos, one after the other on the
first 8 pins of the PCA9685
Pick one up today in the adafruit shop!
------> Adafruit 16-Channel 12-bit PWM/Servo Driver - I2C interface [PCA9685] : ID 815 : $14.95 : Adafruit Industries, Unique & fun DIY electronics and kits
These drivers use I2C to communicate, 2 pins are required to
interface.
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
// called this way, it uses the default address 0x40
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// you can also call it with a different address you want
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
// you can also call it with a different address and I2C interface
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x40, Wire);
// Depending on your servo make, the pulse width min and max may vary, you
// want these to be as small/large as possible without hitting the hard stop
// for max range. You'll have to tweak them as necessary to match the servos you
// have!
#define SERVOMIN 150 // This is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX 600 // This is the 'maximum' pulse length count (out of 4096)
#define USMIN 600 // This is the rounded 'minimum' microsecond length based on the minimum pulse of 150
#define USMAX 2400 // This is the rounded 'maximum' microsecond length based on the maximum pulse of 600
#define SERVO_FREQ 50 // Analog servos run at ~50 Hz updates
// our servo # counter
uint8_t servonum = 0;
Serial.println("8 channel Servo test!");
pwm.begin();
// In theory the internal oscillator is 25MHz but it really isn't
// that precise. You can 'calibrate' by tweaking this number till
// you get the frequency you're expecting!
pwm.setOscillatorFrequency(27000000); // The int.osc. is closer to 27MHz
pwm.setPWMFreq(SERVO_FREQ); // Analog servos run at ~50 Hz updates
delay(10);
// You can use this function if you'd like to set the pulse length in seconds
// e.g. setServoPulse(0, 0.001) is a ~1 millisecond pulse width. It's not precise!
void setServoPulse(uint8_t n, double pulse) {
double pulselength;
pulselength = 1000000; // 1,000,000 us per second
pulselength /= SERVO_FREQ; // Analog servos run at ~60 Hz updates
Serial.print(pulselength); Serial.println(" us per period");
pulselength /= 4096; // 12 bits of resolution
Serial.print(pulselength); Serial.println(" us per bit");
pulse *= 1000000; // convert input seconds to us
pulse /= pulselength;
Serial.println(pulse);
pwm.setPWM(n, 0, pulse);
// Drive each servo one at a time using setPWM()
Serial.println(servonum);
for (uint16_t pulselen = SERVOMIN; pulselen < SERVOMAX; pulselen++) {
pwm.setPWM(servonum, 0, pulselen);
for (uint16_t pulselen = SERVOMAX; pulselen > SERVOMIN; pulselen--) {
// Drive each servo one at a time using writeMicroseconds(), it's not precise due to calculation rounding!
// The writeMicroseconds() function is used to mimic the Arduino Servo library writeMicroseconds() behavior.
for (uint16_t microsec = USMIN; microsec < USMAX; microsec++) {
pwm.writeMicroseconds(servonum, microsec);
for (uint16_t microsec = USMAX; microsec > USMIN; microsec--) {
servonum++;
if (servonum > 7) servonum = 0; // Testing the first 8 servo channels
You have a lot of logic building to do. First learn how to move just one servo. Then start extending your technique to the other 3 servos. Learn to use the bare call without all the demo fluff:
pwm.setPWM(<desired servo>, 0, <pulselength>);
You are giving up far too early.
Next time you post code, please use code tags.
Thank you, I appreciate the guidance. I got further right after I made the post, I guess I let my frustrations get the best of me for a bit.
I'll make sure to use code tags next time.
That's perfectly fine. It's very common to find a solution yourself, but only after posting about it. :slight_smile:
