Modifying code to run multiple MLX90333 sensors with Arduino Micro
Okay this is what I have so far:
#include <SPI.h>
#include <stdint.h>
//*******Arduino MICRO SPI pins********
#define SS 17
#define SCK 15
#define MOSI 16
#define MISO 14
#define SS1 2
byte dataBuffer[8];
  SPI.begin;
  pinMode(SS, OUTPUT);
  pinMode(SCK, OUTPUT);
  pinMode(MOSI, OUTPUT);
  pinMode(MISO, INPUT);
  pinMode(SS1, OUTPUT);
  delay(20); //MLX90333 startup takes 16ms
  SPI.beginTransaction(SPISettings(160000, MSBFIRST, SPI_MODE1)); //320000 is about max
  delay(5);
  int j;
  for (j=0; j<10; j++){
    digitalWrite(SS, LOW);
    delay(20);  //Short delay necessary here
    int i;
    for (i=0; i<8; i++){
      dataBuffer[i] = SPI.transfer(255);  // Must transfer 1's, 0's don't work
    digitalWrite(SS, HIGH);
    SPI.endTransaction();
    Serial.print(dataBuffer[2],8); //Print 3rd byte, MSB for Alpha
    Serial.print(" ,");
    Serial.print(dataBuffer[4],8); //Print 5th byte, MSB for Beta
    Serial.println(" ,");
    digitalWrite(SS1, LOW);
    int i;
    digitalWrite(SS1, HIGH);
    Serial.print(" ,");
I wasn't sure how to use the array, although I can see where it may be useful. Until I understand how to use it, I'll leave it out.
The code does compile and uploads, but when view the serial monitor it only shows two columns where I would like to get four (two for each sensor displaying the two angles of the magnetic field each of them senses.) Furthermore, I the readings I see are all zeroes accept when I make a really rapid movement over one of the sensor- then I see a very short few lines of non-zeros before it goes back to all zeros.
I looked walked through the code a couple times and everything seems like it should work... any suggestions?
