I was going through AVR fuse bits. I came across the fact that an hardware programmer is needed in order to mod the fuse bits. I have an Atmgea8 on a breadboard which I program using my UNO as an ISP. Is there anyway by which I can mod the fuse bits of that chip using my UNO as a hardware programmer. All suggestions are welcome.
Thanks
One method:
You can run that sketch without the SD card if you just want to change fuses.
The normal ArduinoISP sketch will enable changing fuses in the target chip. There are numerous tutorials on how to use it, some of which are still current and work. Although I don't think I've seen a tutorial that is specifically about fuse-changing.
I did a bit of a research and came across these commands to program the fuse bits:
avrdude -c usbtiny -p m32 -U lfuse:w:0b11101111:m
avrdude -c usbtiny -p m32 -U hfuse:w:0b11001001:m
Of course, the binary number has to be modded as per my requirements . What should I put in instead of 'usbtiny'. I know that m32 has to be changed to reflect the chip I use. So, if I mod the above code, have the ISP sketch on my arduino board, will i be able to use avrdude to program the fuse bits just by entering these commands?
Thanks.
Here is a fuse calculator for AVR processors that I book marked that somebody else posted in the past: AVR® Fuse Calculator – The Engbedded Blog
I also use an UNO as a programmer, and what I found very useful is a program called Avrdudess. You can get it here:
It is a GUI front end for Avrdude, and allows you to program the fuses, the EEPROM, and the lock bits as well as the flash memory. Very useful.
Thanks for the gui version. But I see that there are many 'options' which can be selected. Which ones should I choose? Any suggestions regarding the precautions I should take??
Thanks
If you use ArduinoISP use stk500v1
You can see what the IDE use in the programmers.txt. or activate verbose output when doing an upload.
Avrdudess settings:
Programmer: Arduino
MCU: Whatever chip you are going to program
Port: The COM port which the Arduino-as-programmer is attached to.
Baud rate: 19200
Bit rate: leave blank
Options: Check "Disable flash erase (-D)" otherwise you risk erasing the bootloader. The other options can be left unchecked.
I think there is a tutorial on the website which covers how to use the program.
