Hello,
Nick Gammon has written an example of an spark plug ISR interrupt about halfway down the page
http://www.gammon.com.au/interrupts
I would like to use this sketch on an Arduino Nano for an 1 cylinder 2-stroke engine.
In the example the timers are used to control the spark timing delay after the trigger signal, and the spark duration.
I am new to Arduino, so please excuse any “dumb” questions.
I tried to do it the “easy” way using micros(), the Timer1 Library and to use a static ignition angle (e.g 17°)
#define coilPin 7
#define triggerPin 2
#include <TimerOne.h>
volatile unsigned long currentMicros = 0;
volatile unsigned long previousMicros = 0;
unsigned long turnMicros = 0; // Time for one revolution
unsigned long sparkDelay = 0;
int triggerOffset = 90; // Hallsensor mounted 90° before TDC
pinMode(coilPin,OUTPUT);
pinMode(triggerPin,INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(triggerPin),get_time,FALLING);
Timer1.initialize(1000000);
void get_time()
currentMicros = micros();
if ((currentMicros - previousMicros) >= 0) //check for rollover
turnMicros = currentMicros - previousMicros;
previousMicros = currentMicros;
sparkDelay = ((turnMicros/360)*(triggerOffset - 17)); // 17° static to keep it simple
Timer1.attachInterrupt(fire,sparkDelay);
Timer1.start();
void fire()
digitalWrite(coilPin, HIGH);
// delay time spark duration is missing
Timer1.stop();
Nick’s example seems to me much more flexible, so i’d like to modify it.
For the use in my old vespa, it would be nice if the spark delay depends on current revs/min.
How do I implement the rpm measurement?
Next step would be the ignition angle in dependecy of the revs/min
revs/min ignition angle
<=500 10
1250 17
2000 24
3000 24
4000 24
5000 21
6000 19
7000 17
8000 17
9000 17
10000 17
Put it in an array and store in PROGMEM?
Is it possible to interpolate between the points?
Best Regards,
Dietmar
