Modifying SD library code
I came across a programmer I want to build on Solderlabs.de . I customized the PCB, change pins and now I have issues with compiling hte code. The code that gives errors:
void printDirectory(void)
   dir.open(&root, "hex", O_READ);
   while (0 == dir.get_next_entry(my_file_name))
     Serial.println(my_file_name);
     num_hex_files++;
   dir.close();
and also here:
//Get selected image file
    for (byte i=0; i<selected_index; i++)
      dir.get_next_entry(my_file_name);
    char file_name[] = "________.hex";
    for(byte i=0; i<8; i++){file_name[i] = my_file_name[i];}
    Serial.print(my_file_name);
    Serial<< F(".hex* \n");
    Serial<< F("Parsing parameter ... \n");
    entry.open(&dir, file_name, O_READ);
the dir.get_next_entry will always give error when compiling.
Any idea what SD library was used (they wrote internal) or how to modify the code? This is higher C level than mine.
Thanks for help
Feel you gave us enough information?
J-M-L:
If you do, you are the only one.
