Hi there,
I'm using an Arduino SD/wireless shield along with an LCD shield at the same time.
The SD shield uses pins D4,11,12,13*
The LCD uses D4-D10 inclusive.
I believe I could simply cut the D4 and for example D3 pin off the LCD shield and then connect a jumper wire to the D3 leg of the SD shield and connect that to the D4 pin on the LCD (and change the pin in software from D4->D3). This is when the shields are stacked uno->SD shield->LCD. Is this correct?
I'm assuming that it can't be done without cutting several pins on the LCD shield (not terribly important as its only £6)
- It's this one: http://arduino.cc/en/Main/ArduinoWirelessShield (I read somewhere that pin 10 may also be needed but it's not listed on the product page)
