Modifying the HWSerial to make other Framelength possible
I'm working on a modification of HWSerial of Arduino 1.0 to make it possible to select the framelength/parity/stopbits like this:
Serial.begin(9600,9,'E',2);
The setup of the Serial Port works fine now, but im not very familiar with cpp (virtual methods, polimorphism, inheritance, etc.) :frowning:
Why i do this is just because i want to port my working c version of a Vending Machine Interface to Arduino.
This MDB interface need 9,N,1 (which arduino does not support so far).
I want to overload the write method that it takes a uint16_t argument, but when i tried to overload the virtual write method in HWSerial i get compiler errors.
Is it correct that the HWSerial get the write method from print.cpp ?
Would be nice if anybody can tell me which function i have to overload to get this working :slight_smile:
If my explanation is not detailed enough please tell me!
Elias
No. HardwareSerial gets the write() method from the Print class in Print.cpp (case matters, if you haven't figure that out, as do complete names).
