Modifying WideTextFinder library to use hardware serial not softwareserial
Hi All,
I have been using some libraries to talk to some different 3G modules with MEGA328 based boards.
I am now playing with a platform based on a MEGA1280 with a built in 3G module on Serial1
I working my way through the libraries to modify various aspects to work with the fixed physical connections on the board but have got stuck with this library that uses SoftwareSerial and it doesnt like the odd-ball main clock freq on the board (11.0592Mhz)
Any pointers on how to modify it to use Serial1 instead of a SoftwareSerial instance?
WideTextFinder.cpp
#include "WideTextFinder.h"
#define NO_SKIP_CHAR  1  // a magic char not found in a valid numeric field
// private function to read characters from stream
// the constructors allow one and only one of the streams to be initialized
  char WideTextFinder::read()
    char r;
    startMillis = millis();
    if (nSerialStream != NULL)
      while(millis() < (startMillis + timeout))
        if (nSerialStream->available() > 0)
          r=nSerialStream->read();
		  if(debug)
			Serial.print(r);
          return r;
    return 0;     // 0 indicates timeout
  // constructors
  //default timeout is 5 seconds
#if defined(ARDUINO) && ARDUINO >= 100
  WideTextFinder::WideTextFinder(SoftwareSerial &stream, int timeout) :
                  nSerialStream(&stream)
#else
  WideTextFinder::WideTextFinder(NewSoftSerial &stream, int timeout) :
#endif
    this->timeout = timeout * 1000L;
	debug=true;
  void WideTextFinder::setDebug(boolean d)
	debug=d;
  // public methods
  // find returns true if the target string is found
  boolean  WideTextFinder::find(char *target)
    return findUntil(target, NULL);
  // as above but search ends if the terminate string is found
  boolean  WideTextFinder::findUntil(char *target, char *terminate)
    byte targetLen = strlen(target);
    byte index = 0;  // maximum target string length is 255 bytes
    byte termIndex = 0;
    byte termLen = (terminate == NULL ? 0 : strlen(terminate));
    char c;
    if( *target == 0)
       return true;   // return true if target is a null string
    while( (c = read()) != 0){
      if( c == target[index]){
        if(++index >= targetLen){ // return true if all chars in the target match
          return true;
      else{
        index = 0;  // reset index if any char does not match
      if(termLen > 0 && c == terminate[termIndex]){
         if(++termIndex >= termLen)
           return false;       // return false if terminate string found before target string
          termIndex = 0;
    return false;
    // places the string between the prestring  and poststring in the given buffer
    // buffer must be one more than the longest string to get
    // the string will be truncated to fit the buffer length
    // end of string determined by a single character match to the first char of poststring
    // returns the number of characters placed in the buffer (0 means no valid data found)
  int WideTextFinder::getString( char *pre_string, char *post_string, char *buffer, int length)
    if( find(pre_string) ){
      int index = 0;
      *buffer = 0;
      while(index < length-1 ){
        char c = read();
        if( c == 0 ){
          return 0;   // timeout returns 0 !
        else if( c == *post_string ){
          buffer[index] = 0; // terminate the string
          return index;               // data got successfully
        else{
          buffer[index++] = c;
      buffer[index] = 0;
      return index; // Note: buffer full before the closing post_string encountered
    return 0;    //failed to find the prestring
  // getValue method:
  // returns the first valid (long) integer value from the current position.
  // initial characters that are not digits (or the minus sign) are skipped
  // function is terminated by the first character that is not a digit.
  long WideTextFinder::getValue()
      return getValue(NO_SKIP_CHAR); // terminate on first non-digit character
  // as above but a given skipChar is ignored
  // this allows format characters (typically commas) in values to be ignored
  long WideTextFinder::getValue(char skipChar)
      boolean isNegative = false;
      long value = 0;
      char c;
      while( (c = read()) != '-' && (c < '0' || c > '9') && (c!=0) )
         ;// ignore non numeric leading characters
      do{
        if(c == skipChar )
           ; // ignore this charactor
        else if (c==0) // Timeout
           return 0;
        else if(c == '-')
           isNegative = true;
        else if(c >= '0' && c <= '9')        // is c a digit?
           value = value * 10 + c - '0';
        c = read();
      while( (c >= '0' && c <= '9')  || c == skipChar );
      if(isNegative)
        value = -value;
     return value;
  // float version of getValue method:
  // as integer version but returns a floating point value
    float WideTextFinder::getFloat()
       getFloat(NO_SKIP_CHAR);
  // as above but the given skipChar is ignored
  float WideTextFinder::getFloat(char skipChar){
      boolean isFraction = false;
      long value = 0;
      float fValue;
      char c;
      float fraction = 1.0;
      while( (c = read()) != '-' && (c < '0' || c > '9') )
         ; // ignore non numeric leading characters
      do{
        if(c == skipChar)
           ; // ignore
        else if(c == '-')
           isNegative = true;
        else if (c == '.')
            isFraction = true;
        else if(c >= '0' && c <= '9')  {      // is c a digit?
           if(isFraction)
              fraction *= 0.1;
        c = read();
      while( (c >= '0' && c <= '9')  || c == '.' || c == skipChar );
      if(isNegative)
        value = -value;
      if(isFraction)
        return value * fraction;
        return value;
  // returns the number of seconds to wait for the next char before aborting read
  unsigned long WideTextFinder::getTimeout()
	   return timeout;
  // set a new value for the wait timeout
  void WideTextFinder::setTimeout(unsigned long timeout)
second file:
WideTextFinder.h
#ifndef WideTextFinder_h
#define WideTextFinder_h
#include "Arduino.h"
#include <SoftwareSerial.h>
#else
#include "WProgram.h"
#include <NewSoftSerial.h>
#endif
class WideTextFinder {
private:
  SoftwareSerial* nSerialStream;
#else
  NewSoftSerial* nSerialStream;
#endif
  unsigned long timeout;    // number of seconds to wait for the next char before aborting read
  unsigned long startMillis; // used for timeout measurement
  boolean debug;
  char read();             // private function to read from the stream
public:
  // constructor:
  // default timeout is 5 seconds
  WideTextFinder(SoftwareSerial &stream, int timeout = 5);          // Ethernet constructor
#else
  WideTextFinder(NewSoftSerial &stream, int timeout = 5);          // Ethernet constructor
#endif
  // Manage debug
  void setDebug(boolean d);
  // find methods - these seek through the data but do not return anything
  // they are useful to skip past unwanted data
  boolean find(char *target);   // reads data from the stream until the target string is found
  // returns true if target string is found
  boolean findUntil(char *target, char *terminate);   // as above but search ends if the terminate string is found
  // get methods - these get a numeric value or string from the data stream
  long getValue();    // returns the first valid (long) integer value from the current position.
  // integer is terminated by the first character that is not a digit.
  long getValue(char skipChar); // as above but the given skipChar is ignored
  float getFloat();  // float version of getValue
  float getFloat(char skipChar);  // as above but the given skipChar is ignored
  int getString( char *pre_string, char *post_string, char *buffer, int length); //puts string found between given delimiters in buffer
  // string will be truncated to fit the buffer length
  // end of string determined by a match of a character to the first char of close delimiter
	unsigned long getTimeout();   // returns the number of seconds to wait for the next char before aborting read
  // set methods
	void setTimeout(unsigned long timeout);  // set a new value for the wait timeout
#endif
Unless you are trying to support pre-1.0 versions, dump all the #if defined/#else/#endif stuff, keeping only the stuff in the if block.
Then, change the SoftwareSerial name everywhere to HardwareSerial.
Many of the comments in the header file are just plain wrong. Delete the ones that are nonsense.
When you create an instance of the class, pass Serial1 to the constructor.
Thank you PaulS - I successfully worked my way through the nest of library files and have it working
