Modul GSM SIM800L and two board
Hello,
I have a GSM GPRS modul SIM800L.
Is it possible to connect two Arduino Board to parallel connection?
My tests say no…
  • when I connect Arduino bord No1 to Modul, all is OK
  • when I connect Arduino bord No2 to Modul, all is OK
  • when I connect No1 and No2 parallel to modul, modul GSM does not communicate…
I am not sure why… Is my idea right?
Thank
so I found solution myself :slight_smile:
The problem: you can not connect pins Output on the board No1 with pins Output on the board No2!
Solution: You have to connect between pins the diode, so after the paralel connection works well.
