I am trying to generate a modulated square wave using an ATtiny85. It should generate bursts of 38kHz at whatever rate I specify (I will make many of these at different frequencies so that they act as identifiers).
I have had this functioning on a Pro Micro so I am confident the approach is right but I would like to port it to ATtiny85. (I had it working on one Pro Micro but I seem to be bricking all the the subsequent ones and they cost significantly more; plus the physical size difference would be genuinely handy).
When running the code below, I see a perfect output on my oscilloscope for one or two seconds. Then the signal changes to gibberish. I have no idea why and would truly appreciate any input. The oscilloscope is connected to the output of a 38kHz sensor which demodulates the signal.
Yes, I'm not using the same code I used for the Pro Micro. I've found it much harder to come by guides for the Tiny but I thought I had understood the datasheet correctly.
The fact that I get the correct signal for a short amount of time seems to vindicate this at least somewhat. Just need to understand why this signal doesn't stick around
@apf1979@jremington Yeah I believe it's some scope offset problem. I set the offset when I first plugged it in and haven't really thought about it since. It's powered by 5v and the signal is 5v, I've verified that.
@jremington I hadn't heard of ATTinyCore but it seems I was using it too:
http://drazzy.com/package_drazzy.com_index.json
I uploaded your code and I did get a different result. However going back to my original code also gives me the same new result: A signal around 2.4Hz with a duty cycle of 90%.
I've tried multiple ATtiny85s, I've swapped all the other components and wires multiple times, I've got the original Pro Micro still working so can verify the oscilloscope and the reader circuit I have built.
Really banging my head against the wall. Especially as I can't even get back to the problem I originally reported here...
PS, really appreciate that you took the time to try this at home.
As soon as I posted that, I got it working! Realised that when I tried new chips I didn't update the bootloader so they were still running at 1MHz. Flashed it to 8MHz, tried @jremington code again and it works a treat. I haven't tried retracing my steps yet to see exactly where the problem was because I'm going to sit on the sofa now
