module ENC28J60 to use with xively
hi guys i a little bit in trouble!!!
i bought the ethernet module ENC28J60 and i m trying to send data to xively but it is not very easy for me!!!!
i understood that in need to use the library ethercard and not the ethernet library to make the module working well but i have big problem to implement my xively sketch
i will show the example
this is the code the sample that i found in ethercard library
// Simple demo for feeding some random data to Pachube.
// 2011-07-08 <jc@wippler.nl> http://opensource.org/licenses/mit-license.php
// Handle returning code and reset ethernet module if needed
// 2013-10-22 hneiraf@gmail.com
#include <EtherCard.h>
// change these settings to match your own setup
#define FEED "000"
#define APIKEY "xxx"
// ethernet interface mac address, must be unique on the LAN
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
const char website[] PROGMEM = "api.xively.com";
byte Ethernet::buffer[350];
uint32_t timer;
Stash stash;
byte session;
//timing variable
int res = 0;
void setup () {
  Serial.begin(57600);
  Serial.println("\n[Xively example]");
  //Initialize Ethernet
  initialize_ethernet();
void loop () {
  //if correct answer is not received then re-initialize ethernet module
  if (res > 220){
  res = res + 1;
  ether.packetLoop(ether.packetReceive());
  //200 res = 10 seconds (50ms each res)
  if (res == 200) {
    //Generate random info
    float demo = random(0,500);
    word one = random(0,500);
    String msje;
    if (demo < 250){
      msje = "low";
    else{
      msje = "high";
    // generate two fake values as payload - by using a separate stash,
    // we can determine the size of the generated message ahead of time
    byte sd = stash.create();
    stash.print("demo,");
    stash.println(demo);
    stash.print("one,");
    stash.println(one);
    stash.print("mensaje,");
    stash.println(msje);
    stash.save();
    //Display data to be sent
    Serial.println(demo);
    Serial.println(one);
    // generate the header with payload - note that the stash size is used,
    // and that a "stash descriptor" is passed in as argument using "$H"
    Stash::prepare(PSTR("PUT http://$F/v2/feeds/$F.csv HTTP/1.0" "\r\n"
      "Host: $F" "\r\n"
      "X-PachubeApiKey: $F" "\r\n"
      "Content-Length: $D" "\r\n"
      "\r\n"
      "$H"),
    website, PSTR(FEED), website, PSTR(APIKEY), stash.size(), sd);
    // send the packet - this also releases all stash buffers once done
    session = ether.tcpSend();
   const char* reply = ether.tcpReply(session);
   if (reply != 0) {
     res = 0;
     Serial.println(reply);
   delay(50);
void initialize_ethernet(void){
  for(;;){ // keep trying until you succeed
    //Reinitialize ethernet module
    pinMode(5, OUTPUT);
    Serial.println("Reseting Ethernet...");
    digitalWrite(5, LOW);
    digitalWrite(5, HIGH);
    if (ether.begin(sizeof Ethernet::buffer, mymac) == 0){
      Serial.println( "Failed to access Ethernet controller");
      continue;
    if (!ether.dhcpSetup()){
      Serial.println("DHCP failed");
      continue;
    ether.printIp("IP:  ", ether.myip);
    ether.printIp("GW:  ", ether.gwip);
    ether.printIp("DNS: ", ether.dnsip);
    if (!ether.dnsLookup(website))
      Serial.println("DNS failed");
    ether.printIp("SRV: ", ether.hisip);
    //reset init value
    res = 0;
and this one is the one that goes with xively library and the one that i use for my sketch
#include <SPI.h>
#include <Ethernet.h>
#include <HttpClient.h>
#include <Xively.h>
// MAC address for your Ethernet shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// Your Xively key to let you upload data
char xivelyKey[] = "YOUR_XIVELY_API_KEY";
// Analog pin which we're monitoring (0 and 1 are used by the Ethernet shield)
int sensorPin = 2;
// Define the strings for our datastream IDs
char sensorId[] = "sensor_reading";
XivelyDatastream datastreams[] = {
  XivelyDatastream(sensorId, strlen(sensorId), DATASTREAM_FLOAT),
// Finally, wrap the datastreams into a feed
XivelyFeed feed(15552, datastreams, 1 /* number of datastreams */);
EthernetClient client;
XivelyClient xivelyclient(client);
  Serial.println("Starting single datastream upload to Xively...");
  while (Ethernet.begin(mac) != 1)
    Serial.println("Error getting IP address via DHCP, trying again...");
    delay(15000);
  int sensorValue = analogRead(sensorPin);
  datastreams[0].setFloat(sensorValue);
  Serial.print("Read sensor value ");
  Serial.println(datastreams[0].getFloat());
  Serial.println("Uploading it to Xively");
  int ret = xivelyclient.put(feed, xivelyKey);
  Serial.print("xivelyclient.put returned ");
  Serial.println(ret);
  delay(15000);
could you please help me to understand can i use the second sketch with ethercard library?
thanx
Basically, you can't use the second sketch with ENC28J60/Ethercard, because it has a different API.
There was an add-on library uIP that was ported to the ENC28J60 to provide the same Server and Client approach as the "normal" Ethernet library, but I couldn't make it work.
Instead, you should adapt the first sketch to your need.
There is unfortunately very little support for Ethercard. Which explains that you got no direct reply.
