I got an esp8266 connect to the relay module and I can control it from the web.
However, I can only press the button for only sometime 3-4 times and the web seem to be lagging, idle and then the relay module seem to be restart to the time i load the web server.
What are you using for a power supply?
What are the specs/data of the relay?
Thanks.. Tom..
Sorry for late repy. I'm too busy these days. I'll post shortly
I'm also wondering about Power Supply problem or about the relay.
I'll post pictures detail about specs of the relay and the power supple. However the power supply I don't have much information because that I bought from China
Wawa:
As TomGeorge already suggested, an ESP8266 draws way more than that regulator can provide.
Leo..
Is it that the reason why the relay module and ESP keep resetting? I think so but I don't find any other better than the HT7133
Does anyone have other suggestions? Thanks
Define "better".
Have a look at schematic diagrams of USB powered ESP boards, and see what regulator is commonly used.
Some boards can be plugged directly onto a single relay shield, and powered with a cellphone charger with micro-USB lead.
Google "WeMos D1 mini" and WeMos D1 mini relay shield" (see pictures).
Leo..
Wawa:
Define "better".
Leo..
Better means I can't find any other to put it in the power supply (in the picture I posted) to make it 3.3V
I'm using ESP8266 version 1 so I can't plug cell phone charger, so I have to use another one by using other power supply (5V) to make it 3.3V
I find that I have to use 2 different power source to supply to the relay and the ESP to make it work smoothly Is that because the relay module is too bad or that happen to every relay module?
So did you google for shematic diagrams of other ESP8266 development boards (post#13).
If you can't be bothered, then just use the LM1117-3.3
Don't forget the output cap. You can probably omit the input cap, because you did solder the regulator directly on the output cap of the 5volt supply.
Leo..
Wawa:
Leo..
I want to use LM1117, however the order of the pins didn't meet my right order. So it's not very convenient to solder the pins of the LM1117 to the power supply. That's pity! I don't know why the producer of the Power supply put the order of the pins is OUT-GND-IN but everything that I know is alway GND-IN-OUT
