Module Suggestion
Is there any suggestions for what kind of module i can try in this case?
Require at least 14 wire and wifi connect to database(MySQL)
I want to built a prosthetic hand made with 14 servo(as joint) also make this hand able to connect to WiFi and get the data(for controlling servo) on MySQL.
(i used to think of making wire between Esp32(was using NodeMCU) and arduino uno r3,but it might be too bit complicate for the wire)
You started a topic in the Uncategorised category of the forum when its description explicitly tells you not to
Your topic has been moved to a relevant category. Please be careful in future when deciding where to start new topics
thank you sir for the fix,i'm sorry about what i've done.
For the control of 14 servos, Adafruit 16-Channel 12-bit PWM/Servo Shield - I2C interface : ID 1411 : Adafruit Industries, Unique & fun DIY electronics and kits comes to mind as a shield, Adafruit 16-Channel 12-bit PWM/Servo Driver - I2C interface [PCA9685] : ID 815 : Adafruit Industries, Unique & fun DIY electronics and kits as a breakout board.
I've never used them.
i had already use this before,its actually useful,but then ill need to set it on a module which require wifi connection and mysql connection
You have more flexibility with the breakout board version.
If you want one integrated board, I suspect that you have to design one (yourself or by 3rd party) or to spent significant time searching for one.
