module won't operate until i open the serial monitor
Hello arduino lovers
Something strange happened to me (as usual). For my project, i have two adafruit feather 32ua lora modules and i am using arduino ide to program them. I managed to make them working as transceivers a few days ago but today they won’t operate until i open the serial monitor for each COM. When i close the serial monitor they work but slower than intended! I am using my laptop with 2 usb ports to power them. I don’t understand why that happens can someone explain? They were working just fine!
The code is the same provided from adafruit official site
Transmitter code:
// Feather9x_TX
// -*- mode: C++ -*-
// Example sketch showing how to create a simple messaging client (transmitter)
// with the RH_RF95 class. RH_RF95 class does not provide for addressing or
// reliability, so you should only use RH_RF95 if you do not need the higher
// level messaging abilities.
// It is designed to work with the other example Feather9x_RX
#include <SPI.h>
#include <RH_RF95.h>
// for feather32u4
#define RFM95_CS 8
#define RFM95_RST 4
#define RFM95_INT 7
// Change to 434.0 or other frequency, must match RX's freq!
#define RF95_FREQ 868.0
// Singleton instance of the radio driver
RH_RF95 rf95(RFM95_CS, RFM95_INT);
#define LED 13
  pinMode(LED, OUTPUT);
  pinMode(RFM95_RST, OUTPUT);
  digitalWrite(RFM95_RST, HIGH);
  while (!Serial) {
    delay(1);
  delay(100);
  Serial.println("Feather LoRa TX Test!");
  // manual reset
  digitalWrite(RFM95_RST, LOW);
  delay(10);
  delay(10);
  while (!rf95.init()) {
    Serial.println("LoRa radio init failed");
    Serial.println("Uncomment '#define SERIAL_DEBUG' in RH_RF95.cpp for detailed debug info");
    while (1);
  Serial.println("LoRa radio init OK!");
  // Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM
  if (!rf95.setFrequency(RF95_FREQ)) {
    Serial.println("setFrequency failed");
    while (1);
  Serial.print("Set Freq to: "); Serial.println(RF95_FREQ);
  // Defaults after init are 434.0MHz, 13dBm, Bw = 125 kHz, Cr = 4/5, Sf = 128chips/symbol, CRC on
  // The default transmitter power is 13dBm, using PA_BOOST.
  // If you are using RFM95/96/97/98 modules which uses the PA_BOOST transmitter pin, then
  // you can set transmitter powers from 5 to 23 dBm:
  rf95.setTxPower(23, false);
int16_t packetnum = 0;  // packet counter, we increment per xmission
  delay(1000); // Wait 1 second between transmits, could also 'sleep' here!
  Serial.println("Transmitting..."); // Send a message to rf95_server
  digitalWrite(LED, HIGH);
  char radiopacket[20] = "Hello World #      ";
  itoa(packetnum++, radiopacket+13, 10);
  Serial.print("Sending "); Serial.println(radiopacket);
  radiopacket[19] = 0;
  Serial.println("Sending...");
  delay(10);
  rf95.send((uint8_t *)radiopacket, 20);
  digitalWrite(LED, LOW);
  Serial.println("Waiting for packet to complete...");
  delay(10);
  rf95.waitPacketSent();
  // Now wait for a reply
  uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
  uint8_t len = sizeof(buf);
  Serial.println("Waiting for reply...");
  if (rf95.waitAvailableTimeout(1000))
    // Should be a reply message for us now
    if (rf95.recv(buf, &len))
      Serial.print("Got reply: ");
      Serial.println((char*)buf);
      Serial.print("RSSI: ");
      Serial.println(rf95.lastRssi(), DEC);
      Serial.println("Receive failed");
    Serial.println("No reply, is there a listener around?");
Receiver code:
// Feather9x_RX
// Example sketch showing how to create a simple messaging client (receiver)
// It is designed to work with the other example Feather9x_TX
#include <SPI.h>
// for Feather32u4 RFM9x
#define RFM95_CS 8
#define RFM95_RST 4
#define RFM95_INT 7
// Blinky on receipt
#define LED 13
  while (!Serial) {
    delay(1);
  delay(100);
  Serial.println("Feather LoRa RX Test!");
  // manual reset
  delay(10);
  delay(10);
    while (1);
    while (1);
  if (rf95.available())
    // Should be a message for us now
      RH_RF95::printBuffer("Received: ", buf, len);
      Serial.print("Got: ");
      // Send a reply
      uint8_t data[] = "And hello back to you";
      rf95.send(data, sizeof(data));
      Serial.println("Sent a reply");
while (!Serial) {
delay(1);
Juraj:
while (!Serial) {
delay(1);
I deleted these lines and now they start without opening the serial monitor first. When i close the serial monitor though they work much slower. I can see it from the led blinking much slower and in the serial monitor. The packets arrive much slower also. If i press the reset button on the board it goes back to normal speed!
Edit: Also it doesn’t show up the serial prints in the setup without these lines of code.
sirick:
Edit: Also it doesn't show up the serial prints in the setup without these lines of code.
You can use a delay() instead. One or two seconds should work.
More to the point, I don't understand what you're complaining about. If you need to do Serial I/O as part of the project, then you need the monitor window (or PuTTY, Tera Term, etc) to do so. Just open it -- problem solved.
If you don't need to do Serial I/O, then power the Feather with a 5V wall wart plugged into the USB connector. Without an actual USB Host on the other end, the 32u4 will run as expected .... assuming you get rid of the while() loop.
sirick:
that is the purpose of while (!Serial)
gfvalvo:
My complain after Juraj solution was that even if the feathers start working, when i see something on the serial monitor and then close it the feather work much slower than intended. Managed to solve that only by pressing the reset button on the module but still that looks very weird to me that i have to do this.
Anyway after some time working around i have to also report that when i close the serial monitor and they go to work slowly the windows sound plays when you unplug a usb! Then after some time the sound plays again and they go back to regural operation.
