Modulo (%) not calculating correctly
I am working on an altimeter project and I'm trying to get the code to take an integer value and send it out as a series of beeps on a buzzer. I've got the code working except for some error I believe is associated with the modulo math.
int buzzerPin = 2;
  pinMode(buzzerPin, OUTPUT);
    digitalWrite(buzzerPin, 0);           //make sure the buzzer is off
    int beepAltitude = 24245;
    char x = 4;                           //initialize the power of ten variable to 4 (ten thousand)
    if(beepAltitude < 10000)
      x--;
    if(beepAltitude < 1000)
      x--;                                //remove the need to parse (and report) higher altitudes if they aren't present
    Serial.println(beepAltitude, DEC);
    delay(5000);                            //pause between reportings of the altitude
    for(x; x >= 0; x--)                    //this loop starts at a high power of ten and works down counting the amount of altitude of that power
      int divisor = pow(10, x);                    //calculate the power of ten to report on this run through the loop
      char beepCount = beepAltitude / divisor;     //count how many there are of that power of ten (thousands, hundreds, etc)
      beepAltitude = beepAltitude % divisor;       //remove that power of ten once it has been counted (ex: 542 --> 42)
      if(beepCount == 0)
        digitalWrite(buzzerPin, 1);                //long pulse if the number is zero
        delay(250);
        for(char a = 0; a < beepCount; a++)          //this loop makes a beep for each count (ex: 542 would beep 5 times at the 100 power)
          delay(250);
          delay(250);
      delay(750);                            //longer delay between powers of ten
It beeps out the correct values, but every time it performs the modulo math it adds the integer quotient to the remainder. So the above code yields (on the serial port):
24245
4247
251
53
3
0
Only the last 2 remainders are the correct math and the code beeps out the incorrect values (2, 4, 2, 5, 3). No matter what values I try, it always adds whatever the quotient would be to the modulo result. Is there something goofy in my code that I'm not noticing? Can you only modulo up to a certain sized divisor? If the reported altitude is off by a few feet it's not critical, but this shouldn't be happening.
The pow function isn't doing what you'd expect. It only gives correct results when x=0 or 1. For example, the result of pow(10,3) is not 1000, it is 999.
You'll be better off calculating the powers yourself.
Pete
Thanks for the help, that explains the errors. I will fix it by creating a "for" loop to calculate out the divisor using integers.
