modulo (%) operator results
Hello,
I am reading pH values from an analog input and for the integer side division by 100 works well.
For the fractional side, modulo (%) operator works well for results greater than 10, meaning 7.11 gets displayed the right way, but when the fractional is less than 10, like 6, instead of 7.06 I get 7.6 ???
so analog reading 711
PH value integer side; 711/100 ->7
fractional; 711%100 ->11
display; 7.11
analog reading 709
integer; 709/100 ->7
fractional; 709%100 ->9
display; 7.9 !!!
How can I fix this ?
Thank you very much,
Marian
PS. I can go with… if fractional <10 …, but I guess there is a more intelligent way of dealing with this situation.
display; 7.9 !!!!
Make sure you print leading zeros.
How/where are you displaying the value? If it is using Print::print() (directly, or through inheritance), the print method for floats now allows specifying the number of decimal places to show, so it may not be necessary to emulate this anymore.
I have the pH value displayed on an LCD and on this I have a small if loop checking for fractional < 10 and if true print a leading zero since on the LCD I can control the position.
My problem is on the webpage where where I can not control the position. Paul can you please detail how whould you use the print instruction for this ?
Thank you,
Marian
My problem is on the webpage where where I can not control the position.Paul can you please detail how whould you use the print instruction for this ?
I'd need to see your code for getting data for the web page to display.
If you are using the Client/Server classes in the Ethernet library, they both derive from Print, so you should just be able to have something like:
float pH = 7.043;
client.print("pH = ");
client.println(pH, 4); // print 4 decimal places
Thank you Paul.
Here is the code I use:
client.println(""); client.print(ph_val / 100); client.println("."); client.print(ph_val % 100); client.println("");
Can it be optimized ? ph_val is the value provided by the analog read.
cheers,
Marian
Applying Paul’s comment to your code gives
float ph = ph_val  / 100.0 ;  // makes a float with 2 digits
client.println("<td align=center>"); client.print(ph, 2); client.println("</td>");
