modulo or if statement?
Let's say I've got a counter that increments on every cycle of the loop function, and I want whatever I'm doing to repeat every n loops. I can do it in at least two ways. One way uses the mod function, the other uses an if statement:
int n = 100;  // 100 just for the sake of example
int counter = 0;
    doStuff(counter%n);
    counter++;
int counter = 0;
    if (counter == 100) {
        counter = 0;
    doStuff(counter);
    counter++;
Which way is faster, and why?
Thanks :slight_smile:
They are not the same :wink: In the modulo example you only tell doStuff the modulo but counter is still counting beyond n. So that will cause trouble on roll over :wink: Especially because counter is signed :wink:
Think want you wanted was
int counter = 0;
    counter %= n;
    doStuff(counter%n);
    counter++;
But I'm not sure which is faster, I would have to check the assembly etc. But if one is faster then it's going to by marginal. So it doesn't really matter. But I would say the modulo is more consistent, it does the same action every loop as where the if does or does not do the reset step.
Btw, I would say separating the increment and the counting limit is pretty weird. Now you end with the loop ending with counter = 100 as where you actually mean 0...
Well, I am. Limiting the magnitude of counter, and performing an if test is orders of magnitude faster than anything involving division, which modulo does.
Thanks Septillion, I see my mistake now. Whenever I've done it my way in the past I haven't had problems so I've never noticed it. I'll make sure to do it properly in future!
PaulS:
Septillion's code now does limit the magnitude of the counter. Will this help significantly?
Also, I assumed (I guess naively) that % was a bit-manipulation level operation that in some clever way bypassed division completely. Am I to be thoroughly disappointed that it's just division then subtraction like one would do on paper?
JizzaDaMan:
Be disappointed. Also it's safer to test for a greater than or equal on the upper bound, as a general rule, although it works in this case. Also more logical to group the test and increment together as was pointed out.
You didn't illustrate using n as a modulus because you hard coded it, so I'll put it back in.
int n = 100;  // modulus 100 just for the sake of example
int counter = 0;
    doStuff(counter);
    counter++;
    if (counter >= n)
        counter = 0;
Thanks :slight_smile: This is all good to know
