MOFET selection to run 12v
I am trying to control some LED strip lights (12V, 2 AMP) with the arduino and am trying to select the correct MOSFET to handle the load. I thought this one (http://www.vishay.com/docs/91325/sihlz14.pdf) might work but it does not. When connected with all the pull down and limiting resistors, the lights are dim. Then I noticed when I connected the Drain to Source without the gate power was getting through and dimly lighting the lights...I have researched several sites and similar projects but they do not have the same conditions. Any thoughts? Thanks community!
MOSFET - is what I meant to type..
It helps if you tell us how you connected it up.
Here is the link to the schematic:
http://img19.imageshack.us/img19/8075/12vschematic.jpg
Thanks for the help! I am trying to figure out how to get an image on the forum..
You don't need limiting resistors for MOSFETs. Try it without them.
I tried it without and no go. I diconnected the gate and kept the source and drain connected to the projects grounds and power was getting through and I wasn't sure why..
what's the voltage difference between source and gate when it's turned on?
I'll have to check and post tonight.. Thanks for the input
fungus: You don't need limiting resistors for MOSFETs. Try it without them.
What? You shouldn't recommend this - a power MOSFET gate can be in range 1nF to 20nF, that's like a short-circuit load to an Arduino output pin on short timescales - they can only take 40mA abs max so a gate resistor of 150 ohms or so is recommended. The datasheet seems to lack max load capacitance figures, but typical values are around 100pF or so for logic outputs in general, well below nanofarads.
anderscrib: I am trying to control some LED strip lights (12V, 2 AMP) with the arduino and am trying to select the correct MOSFET to handle the load. I thought this one (http://www.vishay.com/docs/91325/sihlz14.pdf) might work but it does not. When connected with all the pull down and limiting resistors, the lights are dim. Then I noticed when I connected the Drain to Source without the gate power was getting through and dimly lighting the lights...I have researched several sites and similar projects but they do not have the same conditions. Any thoughts? Thanks community!
That MOSFET has a rather high Rds(on) of 0.2 ohms, so it will dissipate 800mW for a 2A load - it will run very hot - small heatsink highly recommended. Its perfectly upto the job though as it is logic level and will only lose you 0.4V in voltage drop - clearly you have it wired up wrongly.
If you connect drain to source then you completely bypass the device, and if in that state the LEDs aren't lighting up properly its clearly nothing to do the the MOSFET!
It all depends.
They are specified to 40ma max but can deliver a lot more.
Again, it depends. But in general, for digital switchign applications, anything more than 47ohm here needs to be seriously evaluated, because of potential high switching loss it can cause.
Fig 5. And the gate charge, a far more useful figure than gate capacitance, is specified right on the 1st page.
Typical gate capacitance for a to220/to3p mosfet is 2-3nf.
No, I mean the max capacitance load for the Arduino !!!! And MOSFET gate capacitance varies with transconductance, I've one with 25nF gate capacitance for instance. 300A rating too ;)
I have never paid any attention to that but most digital devices are specified with a 7 - 15pf Cl. Load capacitance isn't as big an issue with an output pin with substantial output resistance. It does matter significantly in a read-modify-write operation.
Driving something like that would be a challenge, for sure.
That's not the best MOSFET around [might get a little hot], but all in all, the ckt should work perfectly fine as per the schematic. For low-frequency on-off switching, the resistor values will be ok. You want the 10K pulldown to keep the load turned off during initial bootup by the Arduino.
IOW, everything looks ok per the schematic, so 95% likelihood you have it wired wrong.
MarkT: If you connect drain to source then you completely bypass the device, and if in that state the LEDs aren't lighting up properly its clearly nothing to do the the MOSFET!
I was getting to that...first we have to get them to light up "dimly" ;-)
MarkT: What? You shouldn't recommend this - a power MOSFET gate can be in range 1nF to 20nF, that's like a short-circuit load to an Arduino output pin on short timescales - they can only take 40mA abs max so a gate resistor of 150 ohms or so is recommended.
OK, we can put it back in again now we know it's not the problem...
I agree, the circuit looks fine on paper. There must be a wiring error somewhere. Time to start measuring voltages at various points in the circuit. The usual culprit is Vgs when people put the transistor before the load in the circuit.
Disconnect the ckt from the Arduino completely, and get it working first on it's own, then hook to the Arduino. When the gate is pulled up [5 to 12V], the Leds should turn on "brightly", not dimly.
The project works! Thank you to EVERYONE on the forum who helped. In short: The MOSFET mentioned in the thread works but I understand not the best one out there...but it does work well.
So how did you get it to work? - Scotty
