Mojave - CH34x USB drivers - installation
I worked on "High Sierra". Everything worked correctly. Arduino IDE was uploading programs to adruino. After upgrade to Mojave Arduino IDE has stopped working. I started searching for how to solve this problem. I used a lot of different tips such as:
  1. Install driver from http://www.wch.cn/download/CH341SER_MAC_ZIP.html
  2. I tried many variantions like delete folders, install driver from brew, restart, recovery mode and other proposition from GitHub - adrianmihalko/ch340g-ch34g-ch34x-mac-os-x-driver: CH340G CH34G CH34X Mac OS X driver
  3. I installed Arduino IDE beta v 1.8.9.
Can someone have a different working solution?
Regards,
Krzysztof
There is a lot of discussion of this issue here:
https://forum.arduino.cc/index.php?topic=570440.0
Hopefully you might find a solution there!
Hi
After many hours of searching and installing various drivers and macOS reinstalled I found that an older version of Silicon Labs driver worked in my situation. Silicon Labs Version 4. I was trying the latest V5 but somebody on their forum suggested that the legacy version wovercoame the problem.
Andrew
Hi Andrew,
Installing Silicon Labs Version 4 works perfectly for me.
Thank you!
carlos
