Hi Guys,
I apologise in advance if these questions are incredibly simple/ over asked. My understand of Arduinos are much below elementary. I have a project which involves creating a simple musical device based on a PING Distance sensor. Currently I have several cases set up which change notes based on distance.
Now what I would like to do is be able to turn the system on and off using a momentary switch which would be able to interrupt any loop.
I have tried if/ else structures, while structures and that would probably be the limit of my understanding. The difficult/ more advanced sections of this code has been created with help from my tutor and I find myself looking at it quite blankly.
Below is the code:
int redPin = 9;
int greenPin = 10;
int bluePin = 11;
const int pingPin = 7;
int speakerOut = 8;
int button = 2;
int onlight = 13;
// Do we want debugging on serial out? 1 for yes, 0 for no
boolean noNote = false;
int noteRead;
int numReadNotes=0;
#include "pitches.h"
// notes in the melody:
int melodyA[] = {
0,0,4,4,5,5,4,3,3,2,2,1,1,0};
float accuracy=0;
int melodyLength = 14;
// note durations: 4 = quarter note, 8 = eighth note, etc.:
int noteDurations[] = {
2, 2, 2, 2, 2, 2, 1, 2, 2, 2, 2, 2, 2, 1 };
void setup(){
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
pinMode(speakerOut, OUTPUT);
pinMode(button, INPUT);
pinMode(onlight, OUTPUT);
Serial.begin (9600);
int state = HIGH; // the current state of the output pin
int reading; // the current reading from the input pin
int previous = LOW; // the previous reading from the input pin
// the follow variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0; // the last time the output pin was toggled
long debounce = 200; // the debounce time, increase if the output flickers
if (reading == HIGH && previous == LOW && millis() - time > debounce) {
if (state == HIGH)
state = LOW;
state = HIGH;
time = millis();
if(state == LOW){
digitalWrite(onlight, HIGH); }
else {
buzz(speakerOut, c, 500);
buzz(speakerOut, g, 300);
delay(50);
buzz(speakerOut, g, 200);
delay( 1000);
//selectSong();
accuracy = 0;
playSong();
readNotes();
//for (int i =0 ; i < songLength; i++){
float accPercent = accuracy/melodyLength;
Serial.print("Accuracy is ");
Serial.print(accPercent*100);
Serial.print("% ");
Serial.println("");
Serial.print(digitalRead(button));
void playSong(){
// iterate over the notes of the melody:
for (int thisNote = 0; thisNote < melodyLength; thisNote++) {
int noteDuration = 1000/noteDurations[thisNote];
playNote(melodyA[thisNote],noteDuration);
void readNotes(){
//reset readNotes (how many notes have been read?)
numReadNotes = 0;
while (numReadNotes< melodyLength){
// establish variables for duration of the ping,
// and the distance result in inches and centimeters:
long duration, cm;
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
int buttonState = 0;
buttonState = digitalRead(button);
// The same pin is used to read the signal from the PING))): a HIGH
// pulse whose duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
pinMode(pingPin, INPUT);
duration = pulseIn(pingPin, HIGH);
// convert the time into a distance
cm = microsecondsToCentimeters(duration);
// Serial.print(cm);
// Serial.print("cm");
if (cm <=80){
noteRead = int(cm/10);
//compare
if (noteRead == melodyA[numReadNotes-1]){
accuracy++;
if (noNote) {
numReadNotes++;
noNote = false;
else {
noNote = true;
noteRead = 8;
playNote(noteRead, 200);
void playNote(int note, int length){
switch (note) {
case 0:
//Serial.println("Zero");
analogWrite(redPin, 255); // RED
analogWrite(greenPin, 0);
analogWrite(bluePin, 0);
buzz(speakerOut, c, length);
case 1:
analogWrite(redPin, 255); // VIOLET
analogWrite(bluePin, 255);
buzz(speakerOut, d, length);
case 2:
analogWrite(redPin, 0); // GREEN
analogWrite(greenPin, 255);
buzz(speakerOut, e, length);
case 3:
analogWrite(redPin, 255); // YELLOW
buzz(speakerOut, f, length);
case 4:
analogWrite(redPin, 0); // BLUE
buzz(speakerOut, g, length);
case 5:
analogWrite(redPin, 255); // ORANGE
analogWrite(greenPin, 30);
buzz(speakerOut, a, length);
case 6:
analogWrite(redPin, 0); // CYAN
buzz(speakerOut, b, length);
case 7:
analogWrite(redPin, 255); // PINK
analogWrite(bluePin, 50);
buzz(speakerOut, C, length);
case 8:
// Serial.println("over 80");
analogWrite(redPin, 255); // WHITE
buzz(speakerOut, 100000, 0);
case 9:
digitalWrite(onlight, LOW);//off
long microsecondsToInches(long microseconds)
// According to Parallax's datasheet for the PING))), there are
// 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
// second). This gives the distance travelled by the ping, outbound
// and return, so we divide by 2 to get the distance of the obstacle.
// See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
long microsecondsToMilimetres(long microseconds)
return microseconds / 29 / .2 ;
void buzz(int targetPin, long frequency, long length) {
long delayValue = 1000000/frequency/2; // calculate the delay value between transitions
//// 1 second's worth of microseconds, divided by the frequency, then split in half since
//// there are two phases to each cycle
long numCycles = frequency * length/ 1000; // calculate the number of cycles for proper timing
//// multiply frequency, which is really cycles per second, by the number of seconds to
//// get the total number of cycles to produce
for (long i=0; i < numCycles; i++){ // for the calculated length of time...
digitalWrite(targetPin,HIGH); // write the buzzer pin high to push out the diaphram
delayMicroseconds(delayValue); // wait for the calculated delay value
digitalWrite(targetPin,LOW); // write the buzzer pin low to pull back the diaphram
delayMicroseconds(delayValue); // wait again for the calculated delay value
Would someone please be kind enough to help.
