Simple single LED circuit with current given from pin 9, following a HIGH return to pin 2.
Pin 2 is a simple circuit with 10kohm resistor and a momentary switch.
Everything works but LED stays on for longer than the momentary press.
I have checked the hardware is not faulty.
When switch pressed and released pin 2 continues to return a high value for several seconds (I have confirmed this by printing to the serial) afterwards?
Is this just residual current? Is there a solution so momentary switch acts like a momentary switch not a delay switch?
benpaddlejones:
We need a better description of your circuit.
benpaddlejones:
How did you check it?
benpaddlejones:
Please post your full sketch. If possible you should always post code directly in the forum thread as text using code tags (</> button on the toolbar). This will make it easy for anyone to look at it, which will increase the likelihood of you getting help. If the sketch is longer than the forum will allow then it's OK to add it as an attachment.
benpaddlejones:
It's either a problem with your circuit or a problem with your code.
benpaddlejones:
benpaddlejones:
I'm using an Arduino Uno and breadboard.
You have miswired the pullup or pulldown resistor on the button somehow, such that the pin is floating.
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
MarkT:
Thanks, you are 100% correct my circuit was wrong, any chance you could direct me to an explanation of the electrical theory? I assumed a simple circuit like in the attached would do the same but I obviously don't understand the pull up/down circuit.
What I don't get is why is the resistor between the switch and ground? When I moved the resistor between the switch and the pin I crashed the controller which seams the logic place to put it?
