With a project in mind and a few videos under my belt, I've made it here with my first button question. I'd like to edit this code so the button I press switches the circuit on momentarily, instead of staying on or off. This button will signal a solenoid to trigger that's coming from a relay and I don't want to burn out this solenoid with constant voltage (from a single button press).
Thanks for your help!
int pbuttonPin = 12;// connect output to push button
int relayPin = 13;// Connected to relay (LED)
int val = 0; // push value from pin 12
int lightON = 0;//light status
int pushed = 0;//push status
 pinMode(pbuttonPin, INPUT_PULLUP);
 pinMode(relayPin, OUTPUT);
 val = digitalRead(pbuttonPin);// read the push button value
 if(val == HIGH && lightON == LOW){
  pushed = 1-pushed;
  delay(100);
 } Â
 lightON = val;
   if(pushed == HIGH){
    Serial.println("Light ON");
    digitalWrite(relayPin, LOW);
  Â
   }else{
    Serial.println("Light OFF");
    digitalWrite(relayPin, HIGH);
Â
   } Â
 delay(100);
Having some familiarity with, and a grasp of, the concepts demo'ed in the first five sketches in: IDE/file/examples/digital will prove quite useful.
Basically, set up a timer which is reset when your (input pullup-connected) button is pressed (ie. connected to circuit ground) and runs when the button is not pressed. If the timer is enabled to run and has not yet reached its preset value, drive the solenoid.
 if (digitalRead(pbuttonPin))
 int val = digitalRead(pbuttonPin);// read the push button value
 if (val == LOW) {
  delay(1000); //select here how long you want the relay stay on
 else {
  delay(100);
