hello to everyone,i need your advice..seems stupid but i cant figure out what is the exact code.I want to make a simple aplic. in VB2010 that switch a Led only at the moment mouse click the button.So far i got it working fine like a toogle switch but i wanted to be momentary swich and there is no exemple anyware.The Arduino code (witch i think it showuld be like) is :
With the MonitorSerial seems to work like i want but i have no clue for the VB
For the VB code i want to start serial comunicacion on Form1_Load and to keep it open until the aplicacion is closed...something like:
Imports System.IO.Ports
Imports System.Threading
Public Class Form1
Dim cambio13 As Boolean = True
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
SerialPort1.Open()
SerialPort1.PortName = "com17" 'Change port COM
SerialPort1.BaudRate = 9600
SerialPort1.DataBits = 8
SerialPort1.Parity = Parity.None
SerialPort1.StopBits = StopBits.One
SerialPort1.Handshake = Handshake.None
SerialPort1.Encoding = System.Text.Encoding.Default
End Sub
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
SerialPort1.Write("1")
End Sub
thank you for reply Paul,you are right,i tried before i post but still cant find the right code...anyway i will keep trying until i get it right.Never lose my hope
What do your Button1_MouseDown and Button1_MouseUp event handlers look like? Did you delete the Button1_Click handler when you added the mouse up and down handlers?
SerialPort1.Close()
SerialPort1.PortName = "com17" 'Chage to your COM
End Sub
Private Sub Button1_MouseDown(ByVal sender As Object, ByVal e As System.Windows.Forms.MouseEventArgs) Handles Button1.MouseDown
SerialPort1.Open()
SerialPort1.Close()
End Sub
Private Sub Button1_MouseUp(ByVal sender As Object, ByVal e As System.Windows.Forms.MouseEventArgs) Handles Button1.MouseUp
SerialPort1.Open()
SerialPort1.Write("2")
SerialPort1.Close()
End Sub
End Class
...simple isnt it¿ ... trying is the key
thank you again Paul and all of this forum
juycce I understand how your VB code works but can't import into visual Studio 2010 Express which I'm just beginning with.
Any suggestion on how this should be imported or copied/pasted into VS would be appreciated.
Regards
Of course, the posted code is only the code behind the form definition code, which was not posted.
You need to define a form with a button on it, called Button1. Then, select the button and look at the properties. At the top of the properties tab, there is a lightening bolt that shows events. Double click in the field next to the MouseDown event. The handler will be created, and you will be switched to the code behind page. Switch back to the form tab, and do the same for the MouseUp event.
Then, switch back to the form view, and double click on the form to add the Load event handler.
Copy and paste the code into the stubs.
Don't forget to add a SerialPort object to the form.
I've had a bit of a play with it late last night but there may be a bit of trap with the original and later version of MsTimer2.h as downloadable from this link Arduino Playground - MsTimer2 I've still to spend more time on it but the original version of MsTimer2 seems to be compatible with the published application code.
Regards all
exactly rbright u need to add to the form a "serialport1" and one single "button".I will keep postin my next projects with arduino-Vb ..this has a huge potencial..u can do millions of things with it
Thanks juycce I now have the searialport added from the toolbox and have successfully duplicated your code and even more.
I've now also had time to get the Arduino Dashboard working as well (see link in my previous post) - a lot of interesting VB code that includes I/O monitoring & control of Arduino including graphing - I'd encourage tinkerers to look at that.
Cheers
