Hello,
Im looking for advice, tips and tricks and if it is possible with arduino to monitor a battery with a total of 20cells.
I need a project and my idea is to make a device using arduino to monitor charge/discharge of a battery with a total of 20cells. In the ens plot data/voltage for each cell.
Is this possible?
Each cell = 0-1.8V.
Which arduino would you recommend? There are only 5 inputs for this on the one i was looking at. If so, i would need to buy several arduinos
Thanks!!
Hello telebrant94
Welcome to the worldbest Arduino forum ever.
Take a search engine of your choice and ask the WWW for 'bms +arduino' to collect some data to be sorted out to get the needed information.
awneil
September 12, 2023, 1:17pm
3
"Monitor Battery Stack" would also be a good search.
My first hit:
Analog Devicesā family of multicell, high voltage battery stack monitors are complete battery monitoring ICs that include 16-bit ADCs, precision voltage references, a high voltage input multiplexer, and a serial interface. Parts can be connected in...
TI are also well-known in the field:
also:
also try distributors:
etc, etc, ...
awneil
September 12, 2023, 1:20pm
4
So which one were you looking at?
You don't necessarily need direct connections to the Arduino; eg, you could multiplex, or use A-to-D converters with bus interfaces...
kolaha
September 12, 2023, 1:30pm
5
any arduino and 2x BQ76930
awneil
September 12, 2023, 1:41pm
6
kolaha:
BQ76930
Indeed - a TI chip:
Other TI chips, and other manufacturers, are available ...
kolaha
September 12, 2023, 2:02pm
7
or 5x quad op-amps and some multiplexer or ADC chip
[Š·Š¾Š±ŃŠ°Š¶ŠµŠ½Š½Ń]
UPD.: it is IRL not so simple and not any OpAmp is suitable.
for example V+ for LM324 must be 1.2V bigger than +Input of highest cell.
Hmm, im curious about the idea behind using OP-AMP?
How are the cells connected?
kolaha
September 17, 2023, 7:12pm
10
idea is to compare two voltages and difference show on output. Li-Ion cells can't have more then 4,35V so Arduino analog input can analyze it.
Wawa
September 17, 2023, 7:56pm
11
Tell us more about that battery.
A stack of 20 cells in series? (0-36volt)
I don't know of a battery that has that voltage range.
Are you talking about 1.25volt NiMh (1-1.45volt).
The "flying capacitor" system is one way to accurately measure a stack of cells.
Leo..
ike621
November 9, 2023, 1:04pm
13
I was wondering where you ended up with this. I came here with the thought of monitoring a Marathon NiCad aircraft Mainship Battery.
system
Closed
May 7, 2024, 1:05pm
14
