//All external libraries are added here
#include "Particle.h"
#include "Adafruit_DHT.h"
#include <Air_Quality.h>
#include "Arduino.h"
#include <TinyGPS++/TinyGPS++.h>
#define DHTPIN 2 // what pin DHT11 sensor is connected to
#define DHTTYPE DHT11 // Type of DHT sensor
#define SoundSensorPin A1 //this pin read the analog voltage from the sound level meter
#define VREF 5.0 //voltage on AREF pin, default:operating voltage
//Object declaration for DHT sensor
DHT dht(DHTPIN, DHTTYPE);
//Object declaration for air quality sensor
Air_Quality airqualitysensor;
//Object declaration for GPS
TinyGPSPlus gps;
//Global variables for the sensor data
char air_quality[20] = "";
float temperature = 0.0;
float humidity = 0.0;
float dbValue = 0.0;
float latitude = 0.0;
float longitude = 0.0;
float startTime;
int current_quality =-1;
bool requestSent = false;
void hookResponseHandler(const char *event, const char *data);
Serial1.begin(9600); //default buad rate for NEO-6M gps is 9600
dht.begin(); //initialize dht sensor
airqualitysensor.init(A0);//initialize air quality sensor
//receive response after publishing data to particle cloud
Particle.subscribe("hook-response/Ubidots", hookResponseHandler, MY_DEVICES);
startTime = millis(); //time count start
if (millis() > startTime + 30000) { //publish data every 30 second
//all the global variables are automatically updated on functions call
read_dht_value();
read_air_quality();
read_sound_level();
publish_data();
while (Serial1.available() > 0){
if (gps.encode(Serial1.read())){
if (gps.location.isValid()){
latitude = gps.location.lat(); //get latitude and longitude
longitude = gps.location.lng();
delay(5000); //Check for gps data every 5 seconds
void hookResponseHandler(const char *event, const char *data) {
float elevation = atof(data);
//this function reads temperature and humidity from dht11 sensor
void read_dht_value() {
//Reading temperature or humidity takes about 250 milliseconds!
//Sensor readings may also be up to 2 seconds 'old' (its a
// very slow sensor)
float h = dht.getHumidity();
//Read temperature as Celsius
float t = dht.getTempCelcius();
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t)) {
return;
else {
temperature = t;
humidity = h;
//this function reads the quality of the air
void read_air_quality()
current_quality=airqualitysensor.slope();
if (current_quality >= 0)// if a valid data returned.
if (current_quality==0)
Serial.println("High pollution! Force signal active");
else if (current_quality==1)
Serial.println("High pollution!");
else if (current_quality==2)
Serial.println("Low pollution!");
else if (current_quality ==3)
Serial.println("Fresh air");
//interrupt service routine for air quality sensor
ISR (TIMER2_OVF_vect)
if(airqualitysensor.counter==122)//set 2 seconds as a detected duty
airqualitysensor.last_vol=airqualitysensor.first_vol;
airqualitysensor.first_vol=analogRead(A0);
airqualitysensor.counter=0;
airqualitysensor.timer_index=1;
PORTB=PORTB^0x20;
airqualitysensor.counter++;
// This function read the data from sound sensor and convert the value into decibel.
void read_sound_level()
float voltageValue;
voltageValue = analogRead(SoundSensorPin) / 1024.0 * VREF;
dbValue = voltageValue * 5.0; //convert voltage to decibel value
void publish_data(){
char data[256];
char data1[256];
//I made two data array because ubidots required position value with a context, firebase doesn't
snprintf(data, sizeof(data), "{\"position\": {\"value\":1, \"context\":{\"lat\": %.6f, \"lng\": %.6f}}, \"temp\":%.2f, \"noise\":%.2f, \"air\": {\"value\":1, \"context\":{\"quality\": \"%s\"}}, \"humid\":%.2f}",
latitude, longitude, temperature, dbValue, air_quality, humidity);
snprintf(data1, sizeof(data1), "{\"lat\": %.6f, \"lng\": %.6f, \"temp\":%.2f, \"noise\":%.2f, \"air\":\"%s\", \"humid\":%.2f}",
Particle.publish("Ubidots", data, PRIVATE); //trigger webhooks for Ubidots
Particle.publish("Google_Sheet", data1, PRIVATE); //trigger webhook to Zapier for uploading to Google Sheet
Particle.publish("Firebase", data1, PRIVATE); //Store data to firebase
Particle.publish("Firebase_put", data1, PRIVATE); //Update data to firebase.
//The main difference here is that the requestType is PUT, not POST. The PUT method doesn't create a table of values;
//it just creates a single element to hold the data, overwriting any previous data at that location.
Where can I find this library?
Code i use to read the Dust Sensor.
void fDoParticleDetector( void * parameter )
ug/m3 AQI Lvl AQ (Air Quality)
(air Quality Index)
0-35 0-50 1 Excellent
35-75 51-100 2 Average
75-115 101-150 3 Light pollution
115-150 151-200 4 moderate
150-250 201-300 5 heavy
250-500 >=300 6 serious
float ADbits = 4095.0f;
float uPvolts = 3.3f;
float adcValue = 0.0f;
float dustDensity = 0.0f;
float Voc = 0.6f; // Set the typical output voltage in Volts when there is zero dust.
const float K = 0.5f; // Use the typical sensitivity in units of V per 100ug/m3.
xEventGroupWaitBits (eg, evtWaitForBME, pdTRUE, pdTRUE, portMAX_DELAY );
TickType_t xLastWakeTime = xTaskGetTickCount();
const TickType_t xFrequency = 100; //delay for mS
for (;;)
//enable sensor led
gpio_set_level( GPIO_NUM_4, HIGH ); // set gpio 4 to high to turn on sensor internal led for measurement
esp_timer_start_once( oneshot_timer, 280 ); // trigger one shot timer for a 280uS timeout, warm up time.
xEventGroupWaitBits (eg, evtDoParticleRead, pdTRUE, pdTRUE, portMAX_DELAY ); // event will be triggered by the timer expiring, wait here for the 280uS
adcValue = float( adc1_get_raw(ADC1_CHANNEL_0) ); //take a raw ADC reading from the dust sensor
gpio_set_level( GPIO_NUM_4, LOW );//Shut off the sensor LED
adcValue = ( adcValue * uPvolts ) / ADbits; //calculate voltage
dustDensity = (adcValue / K) * 100.0; //convert volts to dust density
if ( dustDensity < 0.0f )
dustDensity = 0.00f; // make negative values a 0
if ( xSemaphoreTake( sema_PublishPM, 0 ) == pdTRUE ) // don't wait for semaphore to be available
xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY );
//log_i( "ADC volts %f Dust Density = %ug / m3 ", adcValue, dustDensity ); // print the calculated voltage and dustdensity
MQTTclient.publish( topicInsidePM, String(dustDensity).c_str() );
xSemaphoreGive( sema_MQTT_KeepAlive );
x_eData.PM2 = dustDensity;
vTaskDelayUntil( &xLastWakeTime, xFrequency );
//log_i( " high watermark % d", uxTaskGetStackHighWaterMark( NULL ) );
vTaskDelete( NULL );
}// end fDoParticleDetector()
Enable ILED, wait 280us, take A:D reading, shut down ILED, do the rest of the thing.
What model Arduino are you using?
Tom....
i using an particle argon
What IDE are you using?
Tom...
the ide of particle
#include <Grove_Air_quality_Sensor.h>
AirQualitySensor sensor(A0);
TinyGPSPlus gps;
float startTime;
AirQualitySensor init(A0);//initialize air quality sensor
read_dht_value();
read_air_quality();
read_sound_level();
publish_data();
return;
else {
temperature = t;
humidity = h;
current_quality=AirQualitySensor.slope();
ISR(TIMER2_OVF_vect)
PORTB=PORTB^0x20;
float voltageValue;
char data[256];
char data1[256];
Well its hard to help you if we use the Arduino IDE.
Is there a "particle" forum or QandA site?
What is your electronics, programming, hardware experience?
Did you write this code?
Thanks.. Tom...
