Monitor showing error
hello guys i need help with a project :confused: :confused:
am trying to apply RFID read type RC-522 on arduino uno am a beginner in the arduino and it’s my first time to work on it
i did all the pins fine
but when i upload the code and i start the serial monitor it show
“MFRC522 Software Version: 0x0 (unknown)
WARNING: Communication failure, is the MFRC522 properly connected?
Scan PICC to see UID, type, and data blocks…”
thu the pins is connected well and everything work but i can’t get reading from the RC-522 with any RFID tag am using card tag
this the code i work in i just want to make the reader read tags and save it inside a Database which i still looking for a way to do it i will be grateful for your help and advice’s thank you for your time :slight_smile:
this is the code
 * This is a MFRC522 library example; see https://github.com/miguelbalboa/rfid
 * for further details and other examples.
 * NOTE: The library file MFRC522.h has a lot of useful info. Please read it.
 * Released into the public domain.
 * Example sketch/program showing how to read data from a PICC (that is: a RFID
 * Tag or Card) using a MFRC522 based RFID Reader on the Arduino SPI interface.
 * When the Arduino and the MFRC522 module are connected (see the pin layout
 * below), load this sketch into Arduino IDE then verify/compile and upload it.
 * To see the output: use Tools, Serial Monitor of the IDE (hit Ctrl+Shft+M).
 * When you present a PICC (that is: a RFID Tag or Card) at reading distance
 * of the MFRC522 Reader/PCD, the serial output will show the ID/UID, type and
 * any data blocks it can read. Note: you may see "Timeout in communication"
 * messages when removing the PICC from reading distance too early.
 * If your reader supports it, this sketch/program will read all the PICCs
 * presented (that is: multiple tag reading). So if you stack two or more
 * PICCs on top of each other and present them to the reader, it will first
 * output all details of the first and then the next PICC. Note that this
 * may take some time as all data blocks are dumped, so keep the PICCs at
 * reading distance until complete.
 * Typical pin layout used:
 *             MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
 *             Reader/PCD   Uno           Mega      Nano v3    Leonardo/Micro   Pro Micro
 * Signal      Pin          Pin           Pin       Pin        Pin              Pin
 * RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
 * SPI SS      SDA(SS)      10            53        D10        10               10
 * SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
 * SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
 * SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN		9		//
#define SS_PIN		10		//
MFRC522 mfrc522(SS_PIN, RST_PIN);	// Create MFRC522 instance
	Serial.begin(9600);		// Initialize serial communications with the PC
	while (!Serial);		// Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
	SPI.begin();			// Init SPI bus
	mfrc522.PCD_Init();		// Init MFRC522
	ShowReaderDetails();	// Show details of PCD - MFRC522 Card Reader details
	Serial.println(F("Scan PICC to see UID, type, and data blocks..."));
	// Look for new cards
	if ( ! mfrc522.PICC_IsNewCardPresent()) {
		return;
	// Select one of the cards
	if ( ! mfrc522.PICC_ReadCardSerial()) {
		return;
	// Dump debug info about the card; PICC_HaltA() is automatically called
	mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
void ShowReaderDetails() {
	// Get the MFRC522 software version
	byte v = mfrc522.PCD_ReadRegister(mfrc522.VersionReg);
	Serial.print(F("MFRC522 Software Version: 0x"));
	Serial.print(v, HEX);
	if (v == 0x91)
		Serial.print(F(" = v1.0"));
	else if (v == 0x92)
		Serial.print(F(" = v2.0"));
		Serial.print(F(" (unknown)"));
	Serial.println("");
	// When 0x00 or 0xFF is returned, communication probably failed
	if ((v == 0x00) || (v == 0xFF)) {
		Serial.println(F("WARNING: Communication failure, is the MFRC522 properly connected?"));
/code]
i get it from this site
Odds are your wiring is wrong!
Mark
