monitor wall temperature
hi i wish to know if it's possible to connect temperature sensor into arduino motherboard and check the temperature with rrdtool.
It' possible to monitor a few of rooms together to see the difference between those rooms?
Thanks
That all depends on what the heck rrdtool is.
Same response to your other thread.
Rob
I mean something like these pages you can see what means rrdtool.
http://www.retorte.ch/tools/experiments_and_snippets/arduino_temperature_sensor/
http://solderlab.de/index.php/misc/sensors
I wish to use arduino to monitor wall temperature, sound level meter, and if it's possible wind meter, i wish to know what is better arduino usb or arduino ethernet?
Thanks
Jose
I haven't used an Ethernet shield but shield but talking to a PC with USB is a total no-brainer with Arduino, so I guess I would go that way.
So in answer to your first post, yes it's possible to monitor temperatures and report them to a PC. I'm not convinced 1-wire is good for the distances you infer (ie seperate rooms) but it might be if you use "external power" mode as is shown in figure 5 of that first link.
Rob
