Hi All - I have a project for which I'm toggling 3 latching single coil relays at the same time and I want a simple single input signal to validate voltage is available at the all the relay outputs. Other specifics: Voltages: +5vdc, +12vdc and -12vdc and I want the them to be opto-isolated. The on/off frequency can be hours to weeks, so speed is not a factor. And FWIW, I don't care to know if the voltage is wrong, or which relay might not bet set or if it's one, two or all three are dead, I just need a simple On/Off.
The attachment is a schematic of the simplest arrangement I've come up with but I'll admit this is a little out of my realm. The design is a basic extension of the numerous simple optoisolator breakout boards on the market, I just simply added 2 more stages joining the emitter/collector between each pair and wiring them up to their respective voltages. It works on the breadboard but I'm here to make sure I'm not too far off base.
So:
Q1: Excusing the choice of components, is the logical design ok?
Q2: When it comes to Optos, what's the science in sizing them properly?
Q3: Other options?
Q4: I don't know what I don't know, so what else do I need to know?
And of course feed back on components is welcome too...
Thanks in advance,
-Terry
