I found this code that works great for what I need. But I need to monitor 4 analog ports. This code only monitors 1 port. I have tried to modify the code but with no success. Can some one please give me a hand. Thank you for your time.
Measuring AC Current Using ACS712
const int sensorIn = A0;
int mVperAmp = 185; // use 100 for 20A Module and 66 for 30A Module
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
void setup(){
void loop(){
Voltage = getVPP();
VRMS = (Voltage/2.0) *0.707;
AmpsRMS = (VRMS * 1000)/mVperAmp;
Serial.print(AmpsRMS);
Serial.println(" Amps RMS");
if (AmpsRMS > 0)
Serial.print(" + current! ");
float getVPP()
float result;
int readValue; //value read from the sensor
int maxValue = 0; // store max value here
int minValue = 1024; // store min value here
uint32_t start_time = millis();
while((millis()-start_time) < 1000) //sample for 1 Sec
readValue = analogRead(sensorIn);
// see if you have a new maxValue
if (readValue > maxValue)
/*record the maximum sensor value*/
maxValue = readValue;
if (readValue < minValue)
minValue = readValue;
// Subtract min from max
result = ((maxValue - minValue) * 5.0)/1024.0;
return result;
