Monitoring a reed switch - odd delay?
I’m sure this is probably something quite obvious but I can’t figure it out…or haven’t been able to yet.
I’m trying to monitor a front door in two different ways:
If the doorbell has been rung, I’m trying to monitor if the door actually gets opened within a minute. If not, do stuff().
If the door is opened WITHOUT the doorbell having been rung, I’m trying to do otherstuff().
I’ve more or less got this working, but bizarrely I seem to have a delay somewhere before the microcontroller recognises that the reed switch state has changed. I’m wondering if anyone might have some insight into where this delay is introduced? It’s not hugely important in terms of the functioning of the system I’m trying to build, but I think it probably points at a problem with the system which might cause me OTHER problems down the line (like the front doorbell being pushed being missed!)
thank you!
#include "VineAlert.h"
using namespace RetailAlert;
SYSTEM_THREAD(ENABLED);
// PUB-SUB constants
constexpr char* DEVICE_NAME = "WOO_ALERT";
constexpr char* DOOR_MSSG = "DOOR";
constexpr char* DINING_MSSG = "DINING";
// constructor takes the time in milliseconds, callback function and true if you want it to repeat.
MillisTimer relaytimer(1000, relayCallback, false);
MillisTimer doorbelltimer(60000, doorbellcallback, false);
create IndicatorLED objects
constructor expects the LED pin */
IndicatorLED doorbellLED(D7);
IndicatorLED relayPin(D1);
const int DoorReed = D5;
int DoorBellPushed = 0;
int reedswitch = 0;
int DoorAnswered = 0;
Create ButtonPressAction objects
Constructor expects a pointer to function that executes on button press for example:
ButtonPressAction someButtonName(someFunction);
here we are just using lambdas */
ButtonPressAction doorButton([](){
    if (DoorBellPushed == 0)
	  //Particle.publish(DEVICE_NAME, DOOR_MSSG, 60, PRIVATE);
      Serial << "Doorbell rung\n";
      doorbellLED.on();
	  doorbelltimer.start();
	  DoorAnswered = 0;
	  DoorBellPushed = 1;
	  relayPin.on();
	  relaytimer.start();
ButtonPressAction DININGButton([](){
    Particle.publish(DEVICE_NAME, DINING_MSSG, 60, PRIVATE);
    Serial << "DINING call button rung\n";
// function declarations
void eventHandler(const char* event, const char* data);
  Particle.subscribe(DEVICE_NAME, eventHandler, MY_DEVICES);
  uint32_t startMillis = millis();
  while (millis() - startMillis < 5000){
  doorButton.bindToPin(D0);
  DININGButton.bindToPin(D2);
  pinMode(DoorReed, INPUT);
  digitalWrite(DoorReed, HIGH);           // turn on reed input pin's pull-up resistor
  doorbellLED.begin();
  relayPin.begin();
  doorbelltimer.begin();
  doorbelltimer.start(false);
  relaytimer.begin();
  relaytimer.start(false);
  reedswitch = digitalRead(DoorReed);
  MillisTimer::processTimers();
  ButtonPressAction::update();
  ToggleSwitchAction::update();
  if (reedswitch == HIGH && DoorBellPushed == 1)
	  DoorAnswered = 1;
      doorbellcallback();
	  DoorBellPushed = 0;
      Serial << "Doorbell answered\n";
   if (reedswitch == HIGH && DoorBellPushed == 0)
	   //Serial << "Door opened with key";
      if (reedswitch == LOW && DoorBellPushed == 1)
	   //Serial << "Waiting for an answer";
   if (reedswitch == LOW && DoorBellPushed == 0)
	   //Serial << "Nothin' doing";
  if(strcmp(data, DOOR_MSSG) == 0)
    Serial << "Front Door Button\n";
    doorbellLED.on();
  else if (strcmp(data, DINING_MSSG) == 0)
    Serial << "DINING Button\n";
void relayCallback (void){
	relaytimer.stop();
	relayPin.off();
	Serial << "Relay Off!!\n";
void doorbellcallback (void){
    doorbellLED.off();
	DoorBellPushed = 0;
	Serial << "Doorbell off!!\n";
    doorbelltimer.stop();
	if (DoorAnswered == 0)
	{Serial << "Door went unanswered\n";
READ THIS Particularly # 7!
Paul
Edited my original post. Sorry! I thought it was helpful to do it via Github because my .ino file references two additional files.
This is dumb. Just use delay() if you are going to do nothing.
What board are you running this code on?
