Monitoring and controlling multiple small wind turbines using Arduinos
I am designing a experiment of controlling 6 small wind turbines wirelessly. For each wind turbine, I need to measure power time series (or voltage or current time series) from the generator, and control blade pitch angle, yaw angle, and generator load (using variable resistance). The control input will be all PWM signal.
I am planning to put an Arduino UNO with a ZigBee wireless module to each wind turbine, making it measure the power time series and transmit to the central node, as well as receive the control input from the central node and command the control input to servo motors. The central node will be additional Arduino UNO.
Here are my questions:
Is it possible for each Arduino to send time series signal to central node wirelessly without interference with other Arduino? (6 wind turbines transmitting time series to a central server). If it is possible, How can I implement such network ? recommending a source for learning would be also greatly helpful.
Interface between the central node and the computer software: The algorithm in the computer need to process the received power time series and determine the optimum control input for 6 wind turbines. Then these control input should be transmitted to wirelessly to 6 wind turbines. In such case, what is the good option to interface the algorithm and the Arduino connected to the computer? Currently the algorithm is written in Matlab. I heard there is the sketch interfacing Arduino and Matlab, is it efficient enough for such project?
Xbees or other modules using the Zigbee protocol will take care of issues with multiple units trying to communicate at the same time, but don't expect the same from all types of wireless transceivers. For simple transceivers the error checking needs to be done on the Arduino side using a library like RadioHead.
Be sure to report transmission distance and data rate (bytes/sec or bytes/minute, etc.) with your question.
