Hello everyone!
I am planning to monitoring the state of 16 LEDs connected to a simple board. But the LEDs are switched on using 1,8 volts, so how can I use digital input to check their status? Because digital input on Arduino side only work with voltage > 3 Volts to detect high and low status. Thank you.
Do the LEDs have current limiting resistors?
Voltage on the other side of CL the resistor might be higher.
If the LEDs are connected to ground, you can use a small NPN transistor.
Emitter to ground, base via 1k resistor to LED anode, collector to a digital pin with internal pull up.
Leo..
Wawa:
Voltage on the other side of CL the resistor might be higher.If the LEDs are connected to ground, you can use a small NPN transistor.
Leo..
Thanks WAWA. Is there any option to connect multiple arrays? I was planning to use the ULN2803 but its input senses voltage over 2,4 volts. Thanks again.
The ULN2803 should have a threshold of ~1.3volt, and might work ok with 1.8volt from the LED and the small pull down current of the internal pull up resistors of the Arduino pins.
Leo..
Wawa:
Leo..
Thanks a lot, I´ll give it a try! Best regards.
ULN2803 as octal comparator - clever!
