I am using the PWM to generate a 40kHz signal for an ultrasonic application like this -
TCCR2A = _BV (WGM20) | _BV (WGM21) | _BV (COM2B1); // fast PWM, clear OC2B on compare
TCCR2B = _BV (WGM22) | _BV (CS21); // fast PWM, prescaler of 8
OCR2A = ((F_CPU / 8) / frequency) - 1; // zero relative
OCR2B = ((OCR2A + 1) / 2) - 1; // 50% duty cycle
I want to detect the phase shift between the transmitted and received signal, so I want to be able to detect the state of the PWM pin. Is there any way of doing this internally? It seems a bit daft to have to connect the PWM pin to another pin just to know the state of the PWM pulse (and I’m running out of pins and I have a 328 based board and for various reasons I don’t want to go up to a 1280 or whatever)
