Monitoring Station with ESP32
Hey!
I am designing a monitoring station that includes cameras and meteorological data. I consider myself a beginner, and so I would like to have some tips on how I can improve my code and logic to be a more reliable system. I am using an ESP32 to gather the data and a Raspberry Pi Zero 2W to send the data to my Onedrive. The communication is made via UART. The key points of the data acquisition are:
What I am more doubtful about is the way that I am measuring the wind and rain. I am using a pulse counter to count pulses for a time range of 10 minutes. After those 10 minutes, a flag is set, and the other sensors measure the other data. I don't know if this is the best way to do it or the more reliable. I would like to know your advice!
The code is shown below:
#include "M5UnitENV.h"
#include <driver/pcnt.h>
#include <HardwareSerial.h>
// Data Transmission
#define TX 1
#define RX 3
// Sensor
#define RAIN 25
#define WINDS 18
#define RECORD_TIME 20.0f // seconds
#define WIND_SPEED_ARRAY_SIZE 30 // 30 moments of data acquisition == 10-minute period
#define WIND_SPEED_CONVERSION 2.4f
// Temperature, pressure and humidity sensor library constants
SHT3X sht3x;
QMP6988 qmp;
// Sensor variables
float pSum=0;
float pRead=0;
int pCountSums=0;
int pNoSums=10;
float pAvg=0;
float pAvgHist=0;
float tRead=0;
float hRead=0;
// Data
bool dataSent = false;
// Configuration for the counters
void configurePCNT(int pulsePin, pcnt_unit_t unit, pcnt_channel_t channel);
// Wind
void Windspeed(void *pvParameters) {
  int16_t count = 0;
  float windSpeedValues[WIND_SPEED_ARRAY_SIZE] = {0};
  int windSpeedIndex = 0;
  for (;;) {
    pcnt_counter_clear(PCNT_UNIT_0);
    vTaskDelay(RECORD_TIME * 1000 / portTICK_PERIOD_MS);
    pcnt_get_counter_value(PCNT_UNIT_0, &count);
    float kph = WIND_SPEED_CONVERSION * ((float)count / 2 / RECORD_TIME);
    windSpeedValues[windSpeedIndex++] = kph;
    if (windSpeedIndex >= WIND_SPEED_ARRAY_SIZE) {
      float maxWindSpeed = 0;
      float sumWindSpeed = 0;
      for (int i = 0; i < WIND_SPEED_ARRAY_SIZE; i++) {
        if (windSpeedValues[i] > maxWindSpeed) {
          maxWindSpeed = windSpeedValues[i];
        sumWindSpeed += windSpeedValues[i];
      Serial2.print(maxWindSpeed);
      Serial2.print(",");
      Serial2.print(sumWindSpeed / WIND_SPEED_ARRAY_SIZE);
      Serial2.print(",");
      windSpeedIndex = 0;
// Rain
void Rain(void *pvParameters) {
  int16_t rain_count = 0;
  pcnt_counter_clear(PCNT_UNIT_1);
  while (true) {
    uint32_t start_time = millis();
    uint32_t end_time = start_time + (10 * 60 * 1000); // 10 minutes
    //uint32_t end_time = start_time + (40 * 1000);
    while (millis() < end_time) {
      pcnt_get_counter_value(PCNT_UNIT_1, &rain_count);
      vTaskDelay(1000 / portTICK_PERIOD_MS);
    float volume = rain_count * 0.3f;
    Serial2.print(volume);
    Serial2.print(",");
    dataSent = true;
  Serial2.begin(115200, SERIAL_8N1, RX, TX);
  pinMode(WINDS, INPUT);
  pinMode(RAIN, INPUT);
  configurePCNT(WINDS, PCNT_UNIT_0, PCNT_CHANNEL_0); // contador do vento
  configurePCNT(RAIN, PCNT_UNIT_1, PCNT_CHANNEL_1); // contador da chuva
  // Humidity sensor (I2C)
  if (!qmp.begin(&Wire, QMP6988_SLAVE_ADDRESS_L, 26, 13, 400000U)) {
    Serial.println("Couldn't find QMP6988");
    while (1) delay(1);
  // Temperature and pressure sensor (I2C)
  if (!sht3x.begin(&Wire, SHT3X_I2C_ADDR, 26, 13, 400000U)) {
    Serial.println("Couldn't find SHT3X");
    while (1) delay(1);
  xTaskCreatePinnedToCore(Windspeed, "Windspeed", 10000, NULL, 2, NULL, 1); // Higher priority
  xTaskCreatePinnedToCore(Rain, "Rain", 10000, NULL, 1, NULL, 1); // Lower priority
  // Other sensor readings
  if (dataSent) {
    Pressure();
    Serial2.print(",");
    Temperature();
    Serial2.print(",");
    Humidity();
    Serial2.print(",");
    Winddirection();
    Serial2.print(",");
    Soilmoisture();
    Serial2.println();
    dataSent = false;
void configurePCNT(int pulsePin, pcnt_unit_t unit, pcnt_channel_t channel) {
  int16_t PCNT_H_LIM_VAL = 3000;
  int16_t PCNT_L_LIM_VAL = -10;
  pcnt_config_t pcnt_config = {};
  pcnt_config.pulse_gpio_num = pulsePin;
  pcnt_config.ctrl_gpio_num = PCNT_PIN_NOT_USED;
  pcnt_config.channel = channel;
  pcnt_config.unit = unit;
  pcnt_config.pos_mode = PCNT_COUNT_INC;
  pcnt_config.neg_mode = PCNT_COUNT_DIS;
  pcnt_config.lctrl_mode = PCNT_MODE_KEEP;
  pcnt_config.hctrl_mode = PCNT_MODE_KEEP;
  pcnt_config.counter_h_lim = PCNT_H_LIM_VAL;
  pcnt_config.counter_l_lim = PCNT_L_LIM_VAL;
  pcnt_unit_config(&pcnt_config);
  pcnt_filter_enable(unit);
  pcnt_counter_clear(unit);
Thank you in advance!
Cheers!
using the PCNT (Pulse Counter) module to measure wind speed etc seems a good idea - do you get accurate results?
not sure what the Raspberry Pi Zero 2W is doing that the ESP32 could not do
So far, they have seemed accurate. Sometimes, I have a peak on windspeed, but I think it is because of the sensor's inaccuracy.
As for the Raspberry Pi to create a CSV of the data from that day and send it to my Onedrive. I don't know if ESP32 can send data this way. As far as I know, I can have my ESP32 create a website, but I don't know if it will be too much to have one ESP32 doing all of this, and I need the data on a CSV.
Thank you!
what software are you using on the RPi zero to transmit the CSV data - is it transmitted over WiFi?
The ESP32 has WiFi and is a powerful microcontroller (although not as powerful as the RPi zero) which should be capable of running a website (or other TCP application) and reading the sensors concurrently etc
probably worth a try - saves the serial connection between the devices
or connect the sensors to the RPi zero?
It's transmitted via UART.
At the start of the project, I considered only using the ESP32, but for this project, I needed to save the data in a CSV each day to do data processing, so I found this solution.
That could be a good idea. I need to see the trade-off if the circuit doesn't get too complex in order to do it.
Thank you for the advice! I will study it!
