MONOCHROME 1.3" 128X64 OLED for infrared Thermometer
Hello guys, i am new to arduino and i cannot seem to compile this OLEd display. This is my first time using arduino so i have no idea on anything i was going by what was posted on DIY for a infrared thermometer project. They have some libraries posted and that is what i used but keep getting errors.
Also when i try to post the code using the code insert on the fourm it gives me error message saying it is more then 9000 words. So how else should i post the code for all the helpers to see it.
For Errors i attached snips of it because it was so long and i could not have more than 9000 words. PLEASE IGNORE THE SNIP ATTACHMENTS. Here is a new Error.
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM1
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\pooja\AppData\Local\Temp\arduino_build_573179/kdarjioled.ino.hex"
avrdude: writing flash (20744 bytes):
Writing | ################################################## | 100% 3.49s
avrdude: 20744 bytes of flash written
avrdude: verifying flash memory against C:\Users\pooja\AppData\Local\Temp\arduino_build_573179/kdarjioled.ino.hex:
avrdude: load data flash data from input file C:\Users\pooja\AppData\Local\Temp\arduino_build_573179/kdarjioled.ino.hex:
avrdude: input file C:\Users\pooja\AppData\Local\Temp\arduino_build_573179/kdarjioled.ino.hex contains 20744 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 2.70s
avrdude: verifying ...
avrdude: 20744 bytes of flash verified
avrdude done. Thank you.
Please read the forum instructions.
It explains how to paste code, attach files, ...
And many tips on how to ask questions "well" i.e. how to get the best answers.
Photos are good for pictures of wiring, hardware, diagrams, ..., girllfriends.
Use text for code, opinions, ...
David.
david_prentice:
David.
I did use the code option from the tool bar to post the code but it gives me error for using over 9000 characters.
