Thanks, that's better for my understanding (but still not enough to compile the whole sketch as the included libs are missing ...
This should work (hopefully
unsigned long previousMillis = 0;
const long interval = 1;
#include "Full.c"
#include "Draining.c"
#include "Drained.c"
#include "Empty.c"
#include "Charging.c"
#include "nonBlockingDS18B20.h"
enum machineStates {
IDLE, WAITING_FOR_CONVERSION, ABORTED
const uint8_t ONE_WIRE_BUS = 2; // Change this to Pin # connected to OneWire bus
const uint8_t RESOLUTION = 12;
const unsigned long maxWaitTime = 5000;
const unsigned long interMeasurementPeriod = 1000;
machineStates currentState;
unsigned long measurementStartTime, measurementStopTime;
unsigned long interMeasurementTimer;
OneWire oneWire(ONE_WIRE_BUS);
nonBlockingDS18B20 tempSensors(&oneWire);
void printAddress(DeviceAddress);
uint8_t numDS18;
#define USE_TOUCH 0x2046
#include <virtuabotixRTC.h> //Libraries needed
virtuabotixRTC myRTC(6, 7, 8);
#include "Adafruit_GFX.h" // Hardware-specific library
#include <MCUFRIEND_kbv.h>
#include <SPI.h>
#include <SD.h>
MCUFRIEND_kbv tft; //
#define TFT_BEGIN() tft.begin(0x9488)
#include <XPT2046_Touchscreen.h> // Hardware SPI library
char *name = "Shield XPT2046 Calibration"; //edit name of shield
const int TS_LANDSCAPE = 1; //XPT2046_TouchScreen.h
const int TS_LEFT = 261, TS_RT = 3770, TS_TOP = 3869, TS_BOT = 296;
#define XPT_CS 53 // MEGA2560 SHIELD
#define XPT_IRQ 255 // XPT2046 library does not like IRQ
XPT2046_Touchscreen ts(XPT_CS, XPT_IRQ);
int pixel_x, pixel_y; //Touch_getXY() updates global vars
bool Touch_getXY(void)
bool pressed = ts.touched();
if (pressed) {
TS_Point p = ts.getPoint();
if (TS_LANDSCAPE) mapxy(p.y, p.x);
else mapxy(p.x, p.y);
return pressed;
void Touch_init(void)
ts.begin();
void mapxy(int x, int y) //maps ADC to pixel_x, pixel_y
int aspect = tft.getRotation(); //LANDSCAPE
int tft_width = tft.width();
int tft_height = tft.height();
switch (aspect & 3) {
case 0: //PORTRAIT
pixel_x = map(x, TS_LEFT, TS_RT, 0, tft_width);
pixel_y = map(y, TS_TOP, TS_BOT, 0, tft_height);
case 1: //LANDSCAPE
pixel_x = map(y, TS_TOP, TS_BOT, 0, tft_width);
pixel_y = map(x, TS_RT, TS_LEFT, 0, tft_height);
case 2: //PORTRAIT REV
pixel_x = map(x, TS_RT, TS_LEFT, 0, tft_width);
pixel_y = map(y, TS_BOT, TS_TOP, 0, tft_height);
case 3: //LANDSCAPE REV
pixel_x = map(y, TS_BOT, TS_TOP, 0, tft_width);
pixel_y = map(x, TS_LEFT, TS_RT, 0, tft_height);
Adafruit_GFX_Button temp_btn, humidity_btn, home_btn, more_btn;
#define BLACK 0x0000 /* 0, 0, 0 */
#define NAVY 0x000F /* 0, 0, 128 */
#define DARKGREEN 0x03E0 /* 0, 128, 0 */
#define DARKCYAN 0x03EF /* 0, 128, 128 */
#define MAROON 0x7800 /* 128, 0, 0 */
#define PURPLE 0x780F /* 128, 0, 128 */
#define OLIVE 0x7BE0 /* 128, 128, 0 */
#define LIGHTGREY 0xC618 /* 192, 192, 192 */
#define DARKGREY 0x7BEF /* 128, 128, 128 */
#define BLUE 0x001F /* 0, 0, 255 */
#define GREEN 0x07E0 /* 0, 255, 0 */
#define CYAN 0x07FF /* 0, 255, 255 */
#define RED 0xF800 /* 255, 0, 0 */
#define MAGENTA 0xF81F /* 255, 0, 255 */
#define YELLOW 0xFFE0 /* 255, 255, 0 */
#define WHITE 0xFFFF /* 255, 255, 255 */
#define ORANGE 0xFD20 /* 255, 165, 0 */
#define GREENYELLOW 0xAFE5 /* 173, 255, 47 */
#define PINK 0xF81F
uint8_t displayScreenNo, prevDay, prevMonth, prevSec, prevMin, prevHour, prevVolt, prevMoon;
uint16_t prevYear;
uint8_t index;
static float prevTemp = 999.99 ; // an unlikely value
float currentTempF = tempSensors.getLatestTempC(index);
String nfm = "";
#define SD_CS 48
#define NAMEMATCH ""
#define PALETTEDEPTH 8 // support 256-colour Palette
char namebuf[32] = "/";
File root;
int pathlen;
//myRTC.setDS1302Time(00, 07, 18, 07, 9, 07, 2022);
Serial.begin(2000000);
numDS18 = tempSensors.begin(RESOLUTION);
if (numDS18 == 0) {
Serial.println(
F("Did not locate any DS-type Temperature Sensors, aborting"));
while (1) {
delay(0);
TFT_BEGIN();
bool good = SD.begin(SD_CS);
if (!good) {
Serial.print(F("cannot start SD"));
while (1);
Touch_init();
tft.setRotation(1); //PORTRAIT
tft.fillScreen(BLACK);
home_btn.initButton(&tft, 440, 280, 80, 80, LIGHTGREY, CYAN, BLACK, "HOME", 2);
home_btn.drawButton(false);
more_btn.initButton(&tft, 440, 40, 80, 80, LIGHTGREY, CYAN, BLACK, "MORE", 2);
more_btn.drawButton(false);
temp_btn.initButton(&tft, 440, 120, 80, 80, LIGHTGREY, CYAN, BLACK, "TEMP", 2);
humidity_btn.initButton(&tft, 440, 200, 80, 80, LIGHTGREY, CYAN, BLACK, "%", 2);
temp_btn.drawButton(false);
humidity_btn.drawButton(false);
tft.setTextSize(3);
unsigned int IntensityOfLight;
IntensityOfLight = analogRead(A0);
myRTC.updateTime();
bool down = Touch_getXY();
home_btn.press(down && home_btn.contains(pixel_x, pixel_y));
more_btn.press(down && more_btn.contains(pixel_x, pixel_y));
temp_btn.press(down && temp_btn.contains(pixel_x, pixel_y));
humidity_btn.press(down && humidity_btn.contains(pixel_x, pixel_y));
if (home_btn.justReleased()) {
home_btn.drawButton(true);
more_btn.drawButton();
temp_btn.drawButton();
humidity_btn.drawButton();
if (more_btn.justReleased()) {
more_btn.drawButton(true);
home_btn.drawButton();
if (temp_btn.justReleased()) {
temp_btn.drawButton(true);
if (humidity_btn.justReleased()) {
humidity_btn.drawButton(true);
if (home_btn.justPressed())
prevDay = 99;
prevMonth = 99;
prevYear = 9999;
prevHour = 99;
prevMin = 99;
prevSec = 99;
prevTemp = 999.99;
prevVolt = 9.99;
drawHomeScreen();
displayScreenNo = 1;
if (more_btn.justPressed())
prevDay = 99;
prevMonth = 99;
prevYear = 9999;
prevHour = 99;
prevMin = 99;
prevSec = 99;
prevTemp = 999.99;
prevVolt = 9.99;
drawMoreScreen();
displayScreenNo = 2;
if (temp_btn.justPressed())
prevDay = 99;
prevMonth = 99;
prevYear = 9999;
prevHour = 99;
prevMin = 99;
prevSec = 99;
prevTemp = 999.99;
prevVolt = 9.99;
drawDetailScreenTemp();
displayScreenNo = 3;
if (humidity_btn.justPressed())
prevDay = 99;
prevMonth = 99;
prevYear = 9999;
prevHour = 99;
prevMin = 99;
prevSec = 99;
prevTemp = 999.99;
prevVolt = 9.99;
drawDetailScreenHumidity();
displayScreenNo = 4;
switch (displayScreenNo)
case 1: drawDynHomeScreen(); break;
case 2: drawDynMoreScreen(); break;
case 3: drawDynDetailScreenTemp(); break;
case 4: drawDynDetailScreenHumidity(); break;
void drawHomeScreen() {
tft.drawLine(0, 27, 480, 27, LIGHTGREY);
tft.drawLine(0, 28, 480, 28, LIGHTGREY);
tft.drawLine(200, 0, 200, 28, LIGHTGREY);
tft.drawLine(201, 0, 201, 28, LIGHTGREY);
tft.drawLine(0, 288, 480, 288, LIGHTGREY);
tft.drawLine(0, 289, 480, 289, LIGHTGREY);
tft.drawLine(200, 288, 200, 320, LIGHTGREY);
tft.drawLine(201, 289, 201, 320, LIGHTGREY);
void drawDetailScreenHumidity() {
tft.drawLine(27, 33, 339, 33, LIGHTGREY);
tft.drawLine(27, 59, 339, 59, LIGHTGREY);
tft.drawLine(27, 85, 339, 85, LIGHTGREY);
tft.drawLine(27, 111, 339, 111, LIGHTGREY);
tft.drawLine(27, 137, 339, 137, LIGHTGREY);
tft.drawLine(27, 163, 339, 163, LIGHTGREY);
tft.drawLine(27, 189, 339, 189, LIGHTGREY);
tft.drawLine(27, 215, 339, 215, LIGHTGREY);
tft.drawLine(27, 241, 339, 241, LIGHTGREY);
tft.drawLine(27, 267, 339, 267, LIGHTGREY);
tft.drawLine(27, 293, 339, 293, LIGHTGREY);
tft.drawLine(339, 33, 339, 293, LIGHTGREY);
tft.drawLine(313, 33, 313, 293, LIGHTGREY);
tft.drawLine(287, 33, 287, 293, LIGHTGREY);
tft.drawLine(261, 33, 261, 293, LIGHTGREY);
tft.drawLine(236, 33, 236, 293, LIGHTGREY);
tft.drawLine(209, 33, 209, 293, LIGHTGREY);
tft.drawLine(183, 33, 183, 293, LIGHTGREY);
tft.drawLine(157, 33, 157, 293, LIGHTGREY);
tft.drawLine(131, 33, 131, 293, LIGHTGREY);
tft.drawLine(105, 33, 105, 293, LIGHTGREY);
tft.drawLine(79, 33, 79, 293, LIGHTGREY);
tft.drawLine(53, 33, 53, 293, LIGHTGREY);
tft.drawLine(27, 33, 27, 293, LIGHTGREY);
tft.setTextSize(1);
tft.setTextColor(LIGHTGREY);
tft.setCursor(2, 33);
tft.print("100%");
tft.setCursor(6, 59);
tft.print("90%");
tft.setCursor(6, 85);
tft.print("80%");
tft.setCursor(6, 111);
tft.print("70%");
tft.setCursor(6, 137);
tft.print("60%");
tft.setCursor(6, 163);
tft.print("50%");
tft.setCursor(6, 189);
tft.print("40%");
tft.setCursor(6, 215);
tft.print("30%");
tft.setCursor(6, 241);
tft.print("20%");
tft.setCursor(6, 267);
tft.print("10%");
tft.setCursor(6, 293);
tft.print("0%");
tft.setTextSize(1);
tft.setCursor(26, 300);
tft.print("6");
tft.setCursor(44, 300);
tft.print("5.5");
tft.setCursor(77, 300);
tft.print("5");
tft.setCursor(96, 300);
tft.print("4.5");
tft.setCursor(128, 300);
tft.print("4");
tft.setCursor(148, 300);
tft.print("3.5");
tft.setCursor(181, 300);
tft.print("3");
tft.setCursor(200, 300);
tft.print("2.5");
tft.setCursor(234, 300);
tft.print("2");
tft.setCursor(253, 300);
tft.print("1.5");
tft.setCursor(285, 300);
tft.print("1");
tft.setCursor(305, 300);
tft.print("0.5");
tft.setCursor(337, 300);
tft.print("0");
void drawMoreScreen() {
void drawDetailScreenTemp() {
tft.setTextSize(1);
tft.setCursor(6, 33);
tft.print("45");
tft.print((char)247);
tft.print("40");
tft.print("35");
tft.print("30");
tft.print("25");
tft.print("20");
tft.print("15");
tft.print("10");
tft.print(" 5");
tft.print(" 0");
tft.setCursor(6, 285);
tft.print("-5");
tft.setTextSize(1);
tft.print("6");
tft.print("5.5");
tft.print("5");
tft.print("4.5");
tft.print("4");
tft.print("3.5");
tft.print("3");
tft.print("2.5");
tft.print("2");
tft.print("1.5");
tft.print("1");
tft.print("0.5");
tft.print("0");
void battery () {
int sensor = analogRead(A1);
//Serial.println(sensor);
float voltage = (sensor * 5.0) / 1023;
//Serial.println(voltage);
if (voltage > 3.65) {
tft.drawRGBBitmap(355, 3, Charging, 36, 21);
if ((voltage <= 3.60) && (voltage > 3.20)) {
tft.drawRGBBitmap(355, 3, Full, 36, 21);
if ((voltage <= 3.20) && (voltage > 2.80)) {
tft.drawRGBBitmap(355, 3, Draining, 36, 21);
if ((voltage <= 2.80) && (voltage > 2.40)) {
tft.drawRGBBitmap(355, 3, Drained, 36, 21);
if (voltage <= 2) {
tft.drawRGBBitmap(355, 3, Empty, 36, 21);
void buttons () {
void drawDynHomeScreen() {
tft.setTextSize(3);
tft.setTextColor(WHITE);
if (myRTC.dayofmonth != prevDay)
prevDay = myRTC.dayofmonth;
tft.fillRect(5, 3, 33, 21, BLACK);
tft.setCursor(5, 3);
if (myRTC.dayofmonth < 10)
ShowMoonPhase();
tft.print("0");
tft.print(myRTC.dayofmonth);
ShowMoonPhase();
tft.setCursor(41, 3);
tft.print("/");
if (myRTC.month != prevMonth)
prevMonth = myRTC.month;
tft.fillRect(59, 3, 33, 21, BLACK);
tft.setCursor(59, 3);
if (myRTC.month < 10) {
tft.print("0");
tft.print(myRTC.month);
else {
tft.setCursor(95, 3);
tft.print("/");
if (myRTC.year != prevYear)
prevYear = myRTC.year;
tft.fillRect(113, 3, 70, 21, BLACK);
tft.setCursor(113, 3);
tft.print(myRTC.year);
if (myRTC.hours != prevHour)
prevHour = myRTC.hours;
tft.fillRect(206, 3, 33, 21, BLACK);
tft.setCursor(206, 3);
if (myRTC.hours < 10) {
tft.print("0");
tft.print(myRTC.hours);
else {
tft.setCursor(239, 3);
tft.print(":");
if (myRTC.minutes != prevMin)
prevMin = myRTC.minutes;
tft.fillRect(256, 3, 33, 21, BLACK);
tft.setCursor(256, 3);
if (myRTC.minutes < 10) {
tft.print("0");
tft.print(myRTC.minutes);
else {
tft.setCursor(290, 3);
tft.print(":");
if (currentMillis - previousMillis >= interval) {
if (myRTC.seconds != prevSec)
prevSec = myRTC.seconds;
tft.fillRect(306, 3, 33, 21, BLACK);
tft.setCursor(306, 3);
if (myRTC.seconds < 10) {
tft.print("0");
tft.print(myRTC.seconds);
Serial.print("0");
Serial.println(myRTC.seconds);
else {
if (voltage != prevVolt)
prevVolt = voltage;
battery();
uint8_t index;
static uint32_t loopCount = 0;
switch (currentState) {
case WAITING_FOR_CONVERSION:
if (tempSensors.isConversionDone()) {
// Measurement has finished print results
measurementStopTime = currentMillis;
Serial.print(F(" Sensors Took: "));
Serial.print(measurementStopTime - measurementStartTime);
Serial.println(F(" ms"));
Serial.print(loopCount);
Serial.println(F(" Iterations of loop occurred during this period."));
// Print measurements from all temperature sensors
for (index = 0; index < numDS18; index++) {
Serial.print(F(" Results: "));
Serial.print(tempSensors.getLatestTempC(index), 2);
Serial.println(F(" (C)"));
if (currentTempF != prevTemp)
Serial.print(F("Temp values "));
Serial.print(prevTemp);
Serial.print(F(" "));
Serial.print(currentTempF);
prevTemp = tempSensors.getLatestTempC(index);
Serial.println(prevTemp);
tft.setCursor(5, 294);
tft.fillRect(5, 294, 190, 21, BLACK);
tft.print(tempSensors.getLatestTempC(index), 2);
tft.print(" ");
tft.print("C");
// Hang out until time for next measurement
currentState = IDLE;
interMeasurementTimer = currentMillis;
} else if (currentMillis - measurementStartTime >= maxWaitTime) {
Serial.println(F("Timed Out Waiting for Measurements to Complete -- Aborting"));
currentState = ABORTED;
case IDLE:
// Check if it's time to start another measurement
if (currentMillis - interMeasurementTimer >= interMeasurementPeriod) {
currentState = WAITING_FOR_CONVERSION;
loopCount = 0;
// Kick off another set of non-blocking sensor readings
measurementStartTime = currentMillis;
if (!tempSensors.startConvertion()) {
Serial.println(F("Failed to Start Conversion Cycle, Aborting"));
case ABORTED:
loopCount++;
void drawDynDetailScreenHumidity() {
myRTC.updateTime();
tft.setTextSize(3);
tft.print("0");
tft.print("/");
tft.print("0");
else {
tft.print("/");
tft.print("0");
else {
tft.print(":");
tft.print("0");
else {
prevVolt = voltage;
battery();
void drawDynMoreScreen() {
buttons();
void drawDynDetailScreenTemp() {
myRTC.updateTime();
tft.setTextSize(3);
tft.print("0");
tft.print("/");
tft.print("0");
else {
tft.print("/");
tft.print("0");
else {
tft.print(":");
tft.print("0");
else {
prevVolt = voltage;
battery();
double julianDate(int y, int m, int d) {
// convert a date to a Julian Date}
int mm, yy;
double k1, k2, k3;
double j;
yy = y - int((12 - m) / 10);
mm = m + 9;
if (mm >= 12) {
mm = mm - 12;
k1 = 365.25 * (yy + 4172);
k2 = int((30.6001 * mm) + 0.5);
k3 = int((((yy / 100) + 4) * 0.75) - 38);
j = k1 + k2 + d + 59;
j = j - k3; // j is the Julian date at 12h UT (Universal Time)
return j;
int moon_phase() {
// calculates the age of the moon phase(0 to 7)
// there are eight stages, 0 is full moon and 4 is a new moon
// DateTime now = RTC.now();
double jd = 0; // Julian Date
double ed = 0; //days elapsed since start of full moon
int b = 0;
jd = julianDate(myRTC.year, myRTC.month, myRTC.dayofmonth);
jd = int(jd - 2244116.75); // start at Jan 1 1972
jd /= 29.53; // divide by the moon cycle
b = jd;
jd -= b; // leaves the fractional part of jd
ed = jd * 29.53; // days elapsed this month
nfm = String((int(29.53 - ed))); // days to next full moon
b = jd * 8 + 0.5;
b = b & 7;
return b;
// Returns false if moon_phase() was out of limits OR if showBMP() fails
// For showBMP return codes see the declaration of showBMP()
boolean MoonPhaseBMPLoaded(int mp){
if (0 <= mp && mp <= 7){
char fname[10]; // Could be reduced to [8] ....
sprintf(fname,"/0%d.bmp",mp+1);
return (showBMP(fname, 3, 33) == 0);
} else
return false;
void ShowMoonPhase(){
int mp = moon_phase();
if (!MoonPhaseBMPLoaded(mp)) {
char message[80];
sprintf(message,"Error loading file /0%d.bmp",mp+1);
Serial.println(message);
#define BMPIMAGEOFFSET 54
#define BUFFPIXEL 20
uint16_t read16(File& f) {
uint16_t result; // read little-endian
f.read((uint8_t*)&result, sizeof(result));
return result;
uint32_t read32(File& f) {
uint32_t result;
return result;
uint8_t showBMP(char *nm, int x, int y)
This function returns:
0 : If non of the below applies and the rendering was ok
1 : If the size of the BMP is wider and/or heigher than the tft.screen
2 : if the BMP does not have the ID 0x4D42, the "magic number" that marks a regular BMP
3 : If the BMP contains too many (bit-)planes (more than 1 in this case)
4 : If the BMP is compressed or the colors are not 565 coded (16 Bit per pixel -> 5 Bit Red, 6 Bit Green 5 Bit blue)
5 : If the BMP uses a palette (lookup table)
File bmpFile;
int bmpWidth, bmpHeight; // W+H in pixels
uint8_t bmpDepth; // Bit depth (currently must be 24, 16, 8, 4, 1)
uint32_t bmpImageoffset; // Start of image data in file
uint32_t rowSize; // Not always = bmpWidth; may have padding
uint8_t sdbuffer[3 * BUFFPIXEL]; // pixel in buffer (R+G+B per pixel)
uint16_t lcdbuffer[(1 << PALETTEDEPTH) + BUFFPIXEL], *palette = NULL;
uint8_t bitmask, bitshift;
boolean flip = true; // BMP is stored bottom-to-top
int w, h, row, col, lcdbufsiz = (1 << PALETTEDEPTH) + BUFFPIXEL, buffidx;
uint32_t pos; // seek position
boolean is565 = false; //
uint16_t bmpID;
uint16_t n; // blocks read
uint8_t ret;
if ((x >= tft.width()) || (y >= tft.height()))
return 1; // off screen
bmpFile = SD.open(nm); // Parse BMP header
bmpID = read16(bmpFile); // BMP signature
(void) read32(bmpFile); // Read & ignore file size
(void) read32(bmpFile); // Read & ignore creator bytes
bmpImageoffset = read32(bmpFile); // Start of image data
(void) read32(bmpFile); // Read & ignore DIB header size
bmpWidth = read32(bmpFile);
bmpHeight = read32(bmpFile);
n = read16(bmpFile); // # planes -- must be '1'
bmpDepth = read16(bmpFile); // bits per pixel
pos = read32(bmpFile); // format
if (bmpID != 0x4D42) ret = 2; // bad ID
else if (n != 1) ret = 3; // too many planes
else if (pos != 0 && pos != 3) ret = 4; // format: 0 = uncompressed, 3 = 565
else if (bmpDepth < 16 && bmpDepth > PALETTEDEPTH) ret = 5; // palette
else {
bool first = true;
is565 = (pos == 3); // ?already in 16-bit format
// BMP rows are padded (if needed) to 4-byte boundary
rowSize = (bmpWidth * bmpDepth / 8 + 3) & ~3;
if (bmpHeight < 0) { // If negative, image is in top-down order.
bmpHeight = -bmpHeight;
flip = false;
w = bmpWidth;
h = bmpHeight;
if ((x + w) >= tft.width()) // Crop area to be loaded
w = tft.width() - x;
if ((y + h) >= tft.height()) //
h = tft.height() - y;
if (bmpDepth <= PALETTEDEPTH) { // these modes have separate palette
//bmpFile.seek(BMPIMAGEOFFSET); //palette is always @ 54
bmpFile.seek(bmpImageoffset - (4 << bmpDepth)); //54 for regular, diff for colorsimportant
bitmask = 0xFF;
if (bmpDepth < 8)
bitmask >>= bmpDepth;
bitshift = 8 - bmpDepth;
n = 1 << bmpDepth;
lcdbufsiz -= n;
palette = lcdbuffer + lcdbufsiz;
for (col = 0; col < n; col++) {
pos = read32(bmpFile); //map palette to 5-6-5
palette[col] = ((pos & 0x0000F8) >> 3) | ((pos & 0x00FC00) >> 5) | ((pos & 0xF80000) >> 8);
// Set TFT address window to clipped image bounds
tft.setAddrWindow(x, y, x + w - 1, y + h - 1);
for (row = 0; row < h; row++) { // For each scanline...
// Seek to start of scan line. It might seem labor-
// intensive to be doing this on every line, but this
// method covers a lot of gritty details like cropping
// and scanline padding. Also, the seek only takes
// place if the file position actually needs to change
// (avoids a lot of cluster math in SD library).
uint8_t r, g, b, *sdptr;
int lcdidx, lcdleft;
if (flip) // Bitmap is stored bottom-to-top order (normal BMP)
pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
else // Bitmap is stored top-to-bottom
pos = bmpImageoffset + row * rowSize;
if (bmpFile.position() != pos) { // Need seek?
bmpFile.seek(pos);
buffidx = sizeof(sdbuffer); // Force buffer reload
for (col = 0; col < w; ) { //pixels in row
lcdleft = w - col;
if (lcdleft > lcdbufsiz) lcdleft = lcdbufsiz;
for (lcdidx = 0; lcdidx < lcdleft; lcdidx++) { // buffer at a time
uint16_t color;
// Time to read more pixel data?
if (buffidx >= sizeof(sdbuffer)) { // Indeed
bmpFile.read(sdbuffer, sizeof(sdbuffer));
buffidx = 0; // Set index to beginning
r = 0;
switch (bmpDepth) { // Convert pixel from BMP to TFT format
case 24:
b = sdbuffer[buffidx++];
g = sdbuffer[buffidx++];
r = sdbuffer[buffidx++];
color = tft.color565(r, g, b);
case 16:
if (is565)
color = (r << 8) | (b);
color = (r << 9) | ((b & 0xE0) << 1) | (b & 0x1F);
case 1:
case 4:
case 8:
if (r == 0)
b = sdbuffer[buffidx++], r = 8;
color = palette[(b >> bitshift) & bitmask];
r -= bmpDepth;
b <<= bmpDepth;
lcdbuffer[lcdidx] = color;
tft.pushColors(lcdbuffer, lcdidx, first);
first = false;
col += lcdidx;
} // end cols
} // end rows
tft.setAddrWindow(0, 0, tft.width() - 1, tft.height() - 1); //restore full screen
ret = 0; // good render
bmpFile.close();
return (ret);
As these parts are missing I could not compile it but just give it a try ...
#include "Full.c"
#include "Empty.c"
Just some explanations:
- From your code (post 31) I saw that showBMP returns a value: "ret = showBMP("/01.bmp", 3, 33);" unfortunately not what the value is. So I assumed it as boolean. However now with the full sketch I was able to analyze the return value to be as follows:
uint8_t showBMP(char *nm, int x, int y) returns
0 : If none of the below applies and the rendering was ok
The variable newNfm is declared and filled as a c string by nfm.c_str() at the end of the function "void moonPhase()" but never used. So I removed the line "const char* newNfm = (const char*) nfm.c_str();".
I supported the suggestion of @build_1971 and also @runaway_pancake to use more specific function names: void ShowMoonPhase() replaces moonPhase() and calls a function MoonPhaseBMPLoaded() that returns true if ok or false if not.
MoonPhaseBMPLoaded() returns false if the moonphase is outside of {0..7} or if showBMP() returns anything unequal to zero.
I hope that there is not typo (or any other kind of simple mistake) in the sketch
Looking forward to your results!
If you get any error messages please copy them to the forum like you copy sketches. That is easier to follow than screenshots!
Oops: Had to correct one line in the code ...
Instead of "return (showBMP(fname, 3, 33) != 0);" it must read " return (showBMP(fname, 3, 33) == 0);" of course ...
Please copy the version as it is now
