Mopit rf433 receiver and Arduino compatibility
Hi.
I had some trouble, a few days ago, with my first receiver rf433 receiver and Arduino. Today I was given a different receiver to test it out.
Basically, I want to receive and decode the sent rf433 signal from a proprietary thermo sensor, which periodically sends the signal every 43 seconds (I already know the format of the protocol that the sensor uses).
To test the new receiver out I hooked up:
  • pin2 (GND) of the receiver to GND of my Arduino.
  • pin14 (DATA OUT) to digital pin 7.
  • pin15 (VCC) to 5V.
I than ran the following sketch:
 #define rPin 7           // RF Receiver pin = digital pin 7
 #define ledPin 13        // Onboard LED = digital pin 13
 unsigned int data = 0;   // variable used to store received data
 void setup(){
   pinMode(rPin,INPUT);
   pinMode(ledPin, OUTPUT);
   digitalWrite(ledPin,0);
 void loop(){
   data=digitalRead(rPin);    //listen for data on pin7: 0 or 1
   if(data > 0){
    Serial.println(data);
The read values are always zero (even when the signal is being transmitted). Would anybody know why?
Thank you in advance!
